Hey guys
I have decided to change this group buy into a 400R front bar group buy. I have just found out the order cannot be placed for 2-3 months as they are Very busy completeing a large order at the moment.
Pricing is now below
1-4 - $415 Each
5-10 - $395 Each
Payment - A 50% deposit will be required when the order is placed as to cover the costs to me and my supplier.
Shipping will be around $30 at you door but i can confirm the price when i know the weight of my 400R front bar.
[1] -
[2] -
[3] -
[4] -
[5] -
[6] -
[7] -
[8] -
[9] -
[10] -
Please note the bar below isnt finished but i will post updated pics when i recieve it.
As far as other gear goes i will display that info in time. They are currently working on a kit for R32 GTST 4 Door.
https://www.sau.com.au/forums/topic/70196-skyline-bodykits/
This doesnt sound like a group buy ibfalcon.
If you can supply certain parts at good prices thats fantastic, but you will need to become a trader if you wish to sell these parts here.
Please pm me for more info
https://www.sau.com.au/forums/topic/70196-skyline-bodykits/#findComment-1296811
Hey guys
I just want to see if there was any interest in getting skyline bodykits. Eg i can get a 400r front bar for a r33 gtst for 410+ shippping. I am also able to supply indicators.
There are other kits available too at good prices.
Lee
Im interested in buying a body kit how much are they and what kind are they?
https://www.sau.com.au/forums/topic/70196-skyline-bodykits/#findComment-1299009
Hey guys i have just applied to become a trader. I will post details after my application is processed i dont want to get on the mods bad side.
Can you get these:
Side Skirts
400R Front Bar and skirts
What im after (depending on price) is either the white front bar with the white side skirts or the Black 400r front bar and black side skirts. So if you could get two prices on the two kits it would be much appriciated.
Cheers,
Mitch
https://www.sau.com.au/forums/topic/70196-skyline-bodykits/#findComment-1309812
it aint a 400r front bar www.nismo.com.au have a look at their version of the 400r front bar its fairly decent compared to the REAL thing
I like it better than the 400r front bar, its more unique not many ppl have them were as everyone has a 400r front bar...
https://www.sau.com.au/forums/topic/70196-skyline-bodykits/#findComment-1314869
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
