Hey peoples,
As the topic states I'm in need of a good Manual Gear Box Specialist, I'm having a lot of problems with my Gearbox.
I have an R32 with an Rb20 in it and standard 5 speed.
I probably need a brand new box or a full rebuild.
Can anyone suggest anywhere that can help in Adelaide.
Thanks peoples
Greg
https://www.sau.com.au/forums/topic/70313-gearbox-specialist/
Where can i get a new one with waranty for cheap???
The best quote ive had is $660, but thats just straight out of a front cut, with no warranty :P(  Any sugestions??
I wouldnt think too many places would give warranty, but try Adelaide Jap Dismantlers, they're competitively priced.
www.adelaidejap.com.au
19 Jacobsen Crescent, Holden Hill
Phone 8369 1156.
go to yellow pages and look at wreckers 1, then look at the ones that say import or nissan cars and start ringing
guess what u find out the price and the avaiablity in adeliade for one ask em questions regarding warrantee like how long what voids it ect
but one prob with 32 mans they are kinda weak so if u give em shit even if the car is standard they tend not to like it and go bang or at least crunch, but they are cheap as chips expect around $500 mark with warrantee other option is 33 manual however you need to *4 the price of 32 box and they are really hard to find but they are alot stronger and standard they can handle close to 300rwkw
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
