  • Replies 67
All,
It was a good day, I had fun and got a chance to streatch the R34's legs and make sure the 4WD works, and hopefully master the beast in the wet. I wondered where you went Roy? Lost an alternator thats no good.
Dunks no pete and it was wet!
