r32 gtr radiator is still single row also not much thicker, flows a little better apparently (than gts).
r33 radiators (both) are a bit taller not sure if they will fit, they wouldnt fit in my 180 but r32 gtr one did (also r32 gts fits)
i reckon forget all these as they are not much of an upgrade anyway, maybe get an aftermarket one - you definately need a new radiator?
erm... 115 degrees!
Wow better check it out, i did 4 laps at Phillip Island and a break then 4 laps after that and it only gets to 84.
Don't know if you have an oil cooler or not but a while ago my Gtr heat up a bit me and Troy ( YLWGTR ) went through so much trouble finding out why at the end i take the radiator out sent it to Highway radiator to pull the top tank out, they found out i have up to 75% blockage. Only stupid thing that they did were when i got my radiator back they sprayed it all Black.
Get it check out Marcus.
It is one complete attached core but contains 2 rows.
Have a good look, either that or you've been ripped. :)
not sure of exact terminology in terms of row or core, however I know when you take the cap off the radiators and look in there, on both items there is one thick tube and i would expect it to be the same all the way to the bottom of the radiators. The r33 one is stock in a r33 for sure and 99% sure the other is gtr, but hey maybe there isnt any or much diff between r32 gts/gtr ones.
ofcourse they are one overall core unit but how are they 2 row??
Thanks for the warning, I know it's not good. I've got an oil cooler as well, and on the street the water temp never gets higher than 90.
Also note that Sunday was 30+ degrees at Sandown, and also PI affords much more cooling air to the radiator as it is faster :)
Will invest in a 40mm one when the funds allow!
Oh...
Would have looked scary on the stock guage. :)
Stock gauges are crap! didn't actually move much past middle :confused:
I've got a Defi water temp gauge and it was beeping and flashing it's little brains out (and the temps matched the PFC temps)
    • Before starting any work, we attempted to adjust the tune. However even after adjusting it to certain extremes like completely stopping fuel, it had no effect. What fixed it was removing the Nistune Board and installing the original EPROM instead. This immediately fixed the issue. Everything should have been fine with the Nistune Board installation, so I am unsure why it has caused a problem. The soldered connector is also properly soldered. This worked when I first got the 550cc injectors, before cleaning, but that may have been a coincidence.  We ended up not installing the fuel pump hanger (at least for now). So currently running stock injectors, stock fuel pump, stock fuel pump hanger – Well everything stock except the exhaust. Now I have around €1400 in Nistune, Injectors, and Hanger collecting dust for the time being, perhaps I'll install them in the future. For now I'll enjoy the car as is 😁 Thanks a lot for all your assistance, I really appreciate all the help you have given me.
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
