Hi guys I am relitively new to the club and I am in the process of selling my car and about to buy my first ever boosted car the car I am looking at is a 1997 GTS 5speed manual 2 door coupe in white the car has done a suposedly 107,000klm (can never really believe the odometer) the car has all the usual electrical stuff it only has a Apexi pod filter as far as performance gear goes it also has G-max type 17" rims and full Pioneer sound gear also has a very mild body kit and has not been lowered too much (still looks legal ride hieght) also has a Apexi turbo timer and laserline Car alarm, the car sounds and looks nice but I am unsure due to the pricing of the car as it seems cheap consider age etc, I know I have not given you too much info on the car but I was hoping that I might be able to get an opinion as to what sort of price i should be looking at for buying this car and what else I should be looking at in ways of possible problems the car is located north of perth
any help here would be mostly appreciated
https://www.sau.com.au/forums/topic/70440-what-is-the-value-of-this-r33/
if your south of the river a friend of mine has a very tidy white R33 for sale in rockingham
pm me ill give you his number
Yeah I think I may off seen this particular car advertised his is 104kklm has s/s exhaust filter BOV it is 1995 M spec and is asking $18950.... unfortunately I don't like the rims
you mentioned about a leak test what is this - do you mean like a compression test - any suggestions as to how I can get this done seeing as I live 200klm away from the car and can only get to Perth on weekends or is there another way of checking that everything is ok don't feel like taking the cover and intake pipes off to check spark plugs ect.... what about mobile mechanics how good are they?
and yes the price he is asking is $20k
']last reason to be buying a car is the rims........
sorry I was joking I should of put a smiley in there.... the car looks fine and sounds awesome but it is a couple of years older than the other one that I am looking at.....
I suppose I have spent so much money on my other car that I am not wanting to spend quite so much on a new one and not change too many things over... my Lancer has not many stock parts left on it, it still drives nice and goes great I think I am over the " lets see how much we can change it" so just looking for a stockish (virgin)kind of car.... though I am sure I will end up doing a few minor mods in the way of I/C and exhaust just not yet
well I checked the car out and I was a little disappointed with the car as to general condition it had rust on the bottem edge of the rear window were the screws went in and some of this rust had bubbled.... then there was also rust inside the engine bay on some of the seam welds (not seen that before) then the gentleman had not changed the cam/timing belts at the 100kklm mark - I know you are all going to say that it was probably done when it was first complied I say why risk it... also needed 3 new tyres and a full service
Something I did notice and hopefully someone can help out with this when driving the car the gear box felt notchy and then in general driving I could feel a small vibration coming thru the gear lever is this normal or something to be aware of
So the search continues will check out the car in Rockingham I think as it appears that people who mod there cars are more likely to look after them... I hope
quite normal for a skyline to have a notchy gearbox - especially in second and when its cold.
If you change the oil with redline shockproof lightweight, the notchyness should go away. A bit of vibration through the shifter is normal too. Having aftermarket suspension and wheels tends to increase the NVH of a car.
BTW, if you were after a 94 gtst with a few mods and 78k kms, let me know :D
I think most of the time if the car wasn't owned by a young goon that'll mainly be the case. I know I service my car ever ~4000kms, and include things like new coolant, oil, oil filter, plugs, clean out my pod, detail the engine bay, tighten screws and nuts, check diff oil and gearbox oil condition every time.
I know these things might seem pedantic, but I didn't spend rediculous amounts of fold to let the car go to hell.
Good luck in your search btw :cheers:
Good luck in your search btw :rofl:
I am the same with my Lancer... I know it is just a Lancer but all the same it is my pride and joy and have spent too much money to let it go to hell - the gentleman that has bought the car is getting a hell of a deal after I have seen what is out there on offer
    • I’m here solo don’t have any hands to help so haven’t hit it with a timing light
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
