LOL...3240s, i dont know d1ck about engine building so shouldnt comment. :)
It sounds like a lot of fun...but with turbos that size i would have thought you would need more then mild port and polish, you would need really high lift, long duration cams...extensive headwork and the valvetrane set up to love 10,000rpm cause you wont be seeing 20psi until around 6,000-65000rpm i suspect...so are you still running std ratio gearbox. Anyway im sure you have looked into it and understand it all better then most of us sisnce you have already built the engine
LOL...sounds like awesome fun, and good work for having a go, but i think you will have some work to do making the whole package work. I suppose you can always sell those tasty turbos and go for something a little more sane like twin 2835s:)
Is it a drag car, dyno car...if its a dyno car then get it tuned up on some serious jungle juice and lets see what the beastie can do:)
  • Replies 88
i just got my new engine and very nice indeed what do people think how much power i would make at the rearwheels in a r33gtst put your info in and i give you the honest power figure? as it follows in mods
Rb26 stroked out to 2.8
hks crank
hks rods
hks pistons
N1 nismo cams
hks valves and springs
mild port and polished head
hks cam gears
n1 oil pump
n1 water pump
1000 cc injectors
100 mm throtlebodie
pair of 3240 hks turbos
and running it with motec m800 ecu
3 half in dump pipes into 3 inch nur spec r blitz sys
and nice new pair of fuel pumps and new fuel lines tobe put in
and nismo fuel reg
this it was ive got done and now have all built ?
as im yet to put it in the car i just want peoples thoughts of what power im going to put out in the rear wheels
I find this hard to believe this is real
but if it is there are a few issue with the system
1000cc injector you going to need new fuel rail
N1 fuel regulator i would dont be up to the job
twin 3.5" into one 3" wtf (i run 3.5"single for 320hp turbos)
a twin 3" might get by
N1 cams (why oh why would you skip on cams)
N1 oil pump (you cant be seriously going to run a std flow pump with a 1200hp turbo set up)
and where is your cooling system
5" thick cooler
oil cooler
custom sumpcustom radiator
etc etc
cause if you don't you mos well go burn the money now
ive been talking to steve while hes been in japan... this aint a bullshit thread.. he is a very broke man. lol and is even cutting his holiday time back because he spent to much on little toys... wait and see and drool along with the rest of us. :cheers:
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
