I've decided I don't really need it anymore, as the right side one seems to be operating perfectly fine.
Therefore I'm putting it up forsale.
If anybody can find me a bidder for my kidney, I will give you $1 per every dollar over $10,000 that it fetches. For the successful buyer, I will throw in one slightly cigarette damaged used lung, and one smelly sock.
p.s. does anybody have a rusty spoon handy? and some ice packs?
https://www.sau.com.au/forums/topic/70454-help-me-sell-my-left-kidney/
inspections welcome...
I'm not sure JC.. I'll only take cash for said kidney.. I will not COD, as I do not want my kidney sent back to me with "undelivered return to donor" stamped on it.
So if i can sell it for $100,000, $90,000 is mine and $10,000 is yours?
Um, yes.. I knew there could be an error in this plan :Oops:
I have a phone buyer by the name of Dr H Lecter...he'd like to organise a meeting to suss this kidney out
tastings are extra unfortunately...
actually...... i have a knife here that i just made a vegemite sangga with - when do you want me over?
I hear salt dulls the pain somewhat.. so game on..
joshwa, whatever lies and miss-truths you read on grapevine.com are simply incorrect. This is not a reconditioned kidney, it is not in fact a cut and shut job, it is one genuine Gordon Kidney
are you the first owner
I believe so... although now that I think about it, I may have nabbed it from a monkey one night :confused:
and do you have logbooks??
Yes, I have a through records of when all body wastes have gone in, and out of the kidney.. its quite a few pages long however. Although its possible the life-o-meter has been wound back a bit. So I can't actually substanciate whether the km are genuine.
and is it a genuine kidney or aftermarket?
Its actually a "Hybrid copy" Kidney you see.. made in the same factory is the genuine kidney, but at a fraction of a cost. Its just as good I can guarantee. Flow rate is just as good as the genuine item :)
Nexus, as requested, here are some photos... you'll notice the top image may appear to be slightly shoddy.. but that is just the light of the camera, and I can guarantee no premature wear. Yes the 100,000 hour service has already been done.
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
