A freind of mine tells me i need a high flow catr to make more power, i have a complete 3" systyme and a standard 3" cat.
Does the high flow make that much difference, what about dropping the standard one and slightly damaging it...lol, would this have a better effect on performance?
what you guys &gals reckon?
https://www.sau.com.au/forums/topic/70608-catalic-converter/
  • Replies 52
a 3" hi flow cat would be a good upgrade to finish off the exhaust, and create a lot less restriction, if u start damaging ur cat like gutting it, ur gonna get constant pblack smoke comin out and its bloody annoying, could pick up a cat for round 300 if not look for a 2nd hand gtr one they are quite good
Generally "dropping" and breaking the standard cat you have atm is much better flow and generally much better power, however it ****s up your back pressure. Im not an expert but im going thru the same thing atm.
why on earth would you want backpressure on a turbo motor?
gutting the cat reduces this and thats what you need to aim for for performance gains.
a hi-flo cat isnt bad, a hollow one is better
back pressure is created by turbo and gases passing out of turbo need to get away quick so as not to slow it, a high flow cat is best and from what what ive read in other posts gutting cat works but dont get caught as they retard the release of carciogenics into atmosphere and is whole reason its there. ( supposedly better than releasing lead into air)
How do you get lead in your exhaust emmisions by removing the cat? Here in the UK the first thing anyone does is remove the cat, helps turbo spool up much quicker and makes more bhp at higher revs. You may lose a bit of power at low revs when the turbo isn't spinning because of the loss of back pressure, but it will be minimal. I couldn't feel any loss in power when I removed my cat.
The cat is there for a reason.
Carbon monoxide is dangerous. Dangerous to you, and anyone following you.. Sure you don't care because you're in the cabin but it's also bad for the planet.. (you know, the one you live on, with the polar ice caps melting and the ozone layer hole and stuff).
Also, the difference on a dyno for most cars is sweet **** all.
Now if those 2 logical reasons didn't get you - how about the bullshit fine that's probably half the price of your car that the EPA will bend you over with, and YES believe it or not they do run around with mobile testing stations and even the good ol' broom stick to see if you're gutted it.
So to answer the thread starter - yes a hi flow is the way to go, however stay away from a 4" for example because that may create turbulance. Just stick with your 3" now and if it's gonna die or you have some extra cash, put a high flow in. I'm assuming you have stock turbo/dumppipe/frontpipe. If you upgrade any of those get a high flow too.
Good luck.
Sydneykid said he used a 4" hi flow cat on a 3 or 3.25" exhaust with no power loss.
As for not having a cat in your exh. it's no good for your bank balance "if" you get busted and does greenhouse effect mean anything to you enviro-rapists??
I have been quoted again, at least someone reads them. :headspin:
A quick clarification, same car 3" hi flow cat, made 245 rwkw. Replace with gutted 3" compliance cat, made 252 rwkw. There is turbulance there because of the much larger step up and down in diameter through the gutted cat. You can see the heat differential with a laser heat gun. Replace cat with straight through 3" pipe, 262 rwkw. Fitted Magic 4" cat, 260 rwkw. No tuning changes (fuel or ignition timing ) were made, however the boost does move a little bit as the restriction changes. So I consider it a "real world" test.
Test number 2, put 4" Magic cat on the SupaFlow bench and compared to the "compliance" 3" cat, it flows almost 3 times as much. Over the years we have tested a number of so called "hi flow" 3" cats and none of them gets anywhere near the 4" Magic cat. It is almost as good as a straight though 3" piece of pipe at very high exhaust flows.
So if you don't mind being illegal and an enviro terrorist, a straight though piece of 3" pipe is much better than a gutted cat. Otherwise the 4" Magic cat is a good piece of gear and you can feel safe in the knowledge that your are running legally, making good power and not killing penguins in the antarctic.
:D
PS; we paid for the Magic cat, it wasn't a freebee and there aren't any kick backs. We were doing some testing, as there is ongoing talk of going to cat's for circuit racing (they do it in Germany already).
Still no test as to how the magic cat flows on a big hp car after a few 1000km's of hard driving.
If 265 rwkw is "big hp", then our previous experience with cats (eg; the R34GTT has a hi flow 3.25") has shown that properly tuned (not rich as) means no deterioration for 25,000k's so far. Obviously it only runs on premium unleaded (Optimax mostly), no octane boosters or Avgas. It still makes the same power and it's been a bit over 2 years. I see no reason why the Magic 4" would be any different.
On poorly tuned (especially rich) cars I have seen deterioration in the cat performance after as litttle as 10,000k's of city driving. I have that found a long hard run (5 hours or more) seems to cleans up the cat, as it burns off some of the over rich contaminents. This doesn't work for Avgas (or other leaded fuels) of course, the lead doesn't burn off.
:P
PS; I will come back to this thread when the car with the Magic 4" has done a few more k's.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
