What date for the Go-Kart Day? Vote for more than 1 date if you like.
i voted the first weekend of the new year, becoz i couldnt think of a better way of spending the first weekend of 2003.
too much to organise in december, xmas and new years...save it till after is my vote...
cheers,
franks
A decision is going to have to be made soon on this guys ;)
Whoever is going to step and organise it, just choose one of the popular dates and run with it, otherwise if we keep waiting for one date to be a clear winner, it'll never get organised :P
I nominiate red900ss to make the date - since he is the oldest and wisest SAU exec of the ppl who who have posted so far (on this thread)
What ever date you make Dino there are two ways it can go for me - IN or OUT.
BTW, I nominated 1st or 2nd weeks in Jan (on a Sat or Sun)
PS - Maybe we should make it a Bikini Car Wash Day TOO - like the SAU guys did in WA - ( that's when some lovely young girls come down in bikinis and soap up your car) Young guys can be there for the SAU girls too (if required)
I vote for 5th of Jan lol it's my B'day............nop not really my g/f would disown me if i did went go-karting on my b'day! :uh-huh: Maybe the second w/end could be the best deal!!!!
BTW i am getting the "Corporate Pack" details sent to me in the next couple of days!!!!! So i will be able to inform you guys of the prices, and what u get for your money!!! I know 1 thing though i doubt we will be doing the all-day thing as thaht costs around $300 :eek:
I will basically be trying to get the best deal possible for around the $120-$140 mark??!!!!!:uh-huh: This okay!!!!
Then once the "pack" is determined i will have to get a date for this! I will find out if they are shut at any point!
Neways CATCH YAS
Ando
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
