Rowdyr32 Posted April 22, 2005 Share Posted April 22, 2005 I got some turbos that came with my car yesterday and they are r32 n1 turbos with 0.60 comp and a 0.64 rear housing. I was wondering if you guys know anything about them and there rated power? The comp is bigger than r34 n1 (0.42) turbos and they are rated at 500ps at 1.23 bar. They said that it had late model n1's but I don't know much about the different sizings and power ratings. Link to comment https://www.sau.com.au/forums/topic/71152-60-comp-64-turb-gtr-turbos-power/ Share on other sites More sharing options...
itbmils Posted April 22, 2005 Share Posted April 22, 2005 Rosdyr32 not sure if this will help - but I had R32 N1's on my GTR - and I think they match your specs of 60/.64 BUT They were only rated at 300ps each I think. I now have R34 N1s and they are rated at 320ps each. I've also herd that 18psi (1.23 bar) is about as much as you would want to push them. They will go to 21psi when pushed - but only if you can keep them cool (BIG FMIC) Have a look at the R34 N1's on nismo.com for some more info HtH Link to comment https://www.sau.com.au/forums/topic/71152-60-comp-64-turb-gtr-turbos-power/#findComment-1313032 Share on other sites More sharing options...
Ants Posted April 22, 2005 Share Posted April 22, 2005 I got some turbos that came with my car yesterday and they are r32 n1 turbos with 0.60 comp and a 0.64 rear housing. I was wondering if you guys know anything about them and there rated power? The comp is bigger than r34 n1 (0.42) turbos and they are rated at 500ps at 1.23 bar. They said that it had late model n1's but I don't know much about the different sizings and power ratings. I have R32 nismo Turbos on my R32 GTR and have the same markings as yours do. They are great looking turbos and will perform very well for the street. They are rated at 300ps each and will make very good power at 22pds. I have seen them on an r32 which makes 322kw at all 4 wheels! Excellent turbos and they should look like this: Link to comment https://www.sau.com.au/forums/topic/71152-60-comp-64-turb-gtr-turbos-power/#findComment-1313146 Share on other sites More sharing options...
Rowdyr32 Posted April 22, 2005 Author Share Posted April 22, 2005 thanks guys I did a search as well and they are only r32 n1's but they have no shaft play so I'll put them on and see how they go. At what type of revs do they make boost and when do they reach full boost? At what power output will I max out the stock injectors. Also when I turn the car off the fuel pump stops but another pump goes for about 5 seconds. What is it? Link to comment https://www.sau.com.au/forums/topic/71152-60-comp-64-turb-gtr-turbos-power/#findComment-1313278 Share on other sites More sharing options...
itbmils Posted April 22, 2005 Share Posted April 22, 2005 Mine started boosting @ ~3k rpm - and held good power all the way to the red line - even past it some times -> 8500rpm and still pulling strong I was getting a good 8-9psi by 3500rpm – but I was not running with an EBC at that time. full boost by 5K rpm WOW - 22 psi - what's the diff between N1s and Nismos - anyone ? Link to comment https://www.sau.com.au/forums/topic/71152-60-comp-64-turb-gtr-turbos-power/#findComment-1313391 Share on other sites More sharing options...
BK Posted April 23, 2005 Share Posted April 23, 2005 If you guys have 0.60 compressor and 0.64 exhaust housings they are not N1's. They're Nismo/Garrett Group A turbos. N1's have same housing A/R's as stock on both sides (Compressor 0.42, Exhaust 0.48). It's the way N1 turbo wheels are shaped as well as the housing internal paths that give more power. N1 turbos are apparently good for at least 280 -300 rwkW with Group A turbos have been proven for 350 rwkW+. Bigger compressor housings aren't naturally a better choice, especially on a GT-R. For this reason I chose GT-R spec HKS GT-SS turbos. Remember too much compressor flow at the wrong rpm will make a relatively stock and untuned car surge. Now can you tell me why HKS rate the GT-R spec GT-SS at 320 ps each (0.42 Compressor, 0.64 Exhaust) and the generic GT-SS (0.60 Compressor, 0.64 Exhaust housings) at 280 ps ? It's all to do with developing the wheel shapes and inside housing shapes for particular engines and purposes. My GT-SS turbos hit 1.3 bar by 3500rpm mate. In a GT-R 5000rpm is way too late for a street circuit car. Genuine N1 and GT-SS turbos will kill Group A turbos in reponse full stop. My point, don't go too big. (Like GT-RS turbos for the street. Not good.) Link to comment https://www.sau.com.au/forums/topic/71152-60-comp-64-turb-gtr-turbos-power/#findComment-1315346 Share on other sites More sharing options...
wrxhoon Posted April 23, 2005 Share Posted April 23, 2005 [quote=. My GT-SS turbos hit 1.3 bar by 3500rpm mate. 1.3 Bar @3500 rpm ? what other mods do you have ? I have the same turbos for my car , havent put them in yet but would love to have 1.3 bar even @ 4000 rpm in my stock internals engine . Link to comment https://www.sau.com.au/forums/topic/71152-60-comp-64-turb-gtr-turbos-power/#findComment-1315439 Share on other sites More sharing options...
Driver Posted April 23, 2005 Share Posted April 23, 2005 http://members.iinet.net.au/~drath/N1vsStock.txt Link to comment https://www.sau.com.au/forums/topic/71152-60-comp-64-turb-gtr-turbos-power/#findComment-1315632 Share on other sites More sharing options...
JAGR33 Posted April 24, 2005 Share Posted April 24, 2005 If you guys have 0.60 compressor and 0.64 exhaust housings they are not N1's.They're Nismo/Garrett Group A turbos. N1's have same housing A/R's as stock on both sides (Compressor 0.42, Exhaust 0.48). It's the way N1 turbo wheels are shaped as well as the housing internal paths that give more power. N1 turbos are apparently good for at least 280 -300 rwkW with Group A turbos have been proven for 350 rwkW+. Bigger compressor housings aren't naturally a better choice, especially on a GT-R. For this reason I chose GT-R spec HKS GT-SS turbos. Remember too much compressor flow at the wrong rpm will make a relatively stock and untuned car surge. Now can you tell me why HKS rate the GT-R spec GT-SS at 320 ps each (0.42 Compressor, 0.64 Exhaust) and the generic GT-SS (0.60 Compressor, 0.64 Exhaust housings) at 280 ps ? It's all to do with developing the wheel shapes and inside housing shapes for particular engines and purposes. My GT-SS turbos hit 1.3 bar by 3500rpm mate. In a GT-R 5000rpm is way too late for a street circuit car. Genuine N1 and GT-SS turbos will kill Group A turbos in reponse full stop. My point, don't go too big. (Like GT-RS turbos for the street. Not good.) 1.3 bar at 3500rpm???? WTF??? Are you running an RB 30/ OS 3 litre???? Stock turbos get full boost at about 3500rpm, surely GTSS's won't?!?!?! Link to comment https://www.sau.com.au/forums/topic/71152-60-comp-64-turb-gtr-turbos-power/#findComment-1316456 Share on other sites More sharing options...
BK Posted April 25, 2005 Share Posted April 25, 2005 1.3 bar at 3500rpm???? WTF???Are you running an RB 30/ OS 3 litre???? Stock turbos get full boost at about 3500rpm, surely GTSS's won't?!?!?! Nah mate. The exhaust manifolds are mega dollar Kaminali's. They are so wicked combined with my custom exhaust with zero backpressure. HKS dumps, HKS 2 x 70/85mm stainless front pipe then 4 inch Magic cat (get one - they flow 750 cfm), 90 mm rest of the way with NO RESONATOR to a HKS 95mm/120mm muffler. It's way better than the Hi power HKS setup. I had this set up on std turbos bar the cat and manifolds. Changed to the manifolds and within 5km of driving the car the front turbo violently snapped the wheel off at only 1 bar at 3000rpm! Seriously these manifolds made the world of diiference, if you look at the exhaust flange for the turbo - there's about 50% more air hitting the exhaust wheel. I chaged turbos not long after so I've never driven with the stock manifolds with GT-SS turbos. Never driven any other modified GT-R's either but I am just saying what actually happens in the car. It's an absolute animal off the bottom. I've G-tech it and it does 0-100 in a best so far of 4.11 seconds with ceramic button Xclutch.The ball bearing nature of the GT-SS turbos really are that good.You spin stock turbos with your fingers, they stop very quickly(second or so). My GT-SS turbos keep spinning for about 25 seconds and the wheels also weigh less than stockers. When the engine is revved (Stationary)to 4000rpm or so you can actually HEAR the turbos spooling down for about 40 - 50 seconds through the exhaust or the air cleaners. I've seen another car with 2530 turbos hit 20psi by 2800rpm with the RB30/26 combo to answer the 3 litre question. Also that link with the reference to the N1's I've held the roller N1's(I nearly bought them) and it definatly has a big .48 on the exhaust entry. Look I'm not a big net surfer and jump on forums bugger all. This is all just from modifying my own cars and what I've found out whilst doing so. Link to comment https://www.sau.com.au/forums/topic/71152-60-comp-64-turb-gtr-turbos-power/#findComment-1317540 Share on other sites More sharing options...
JAGR33 Posted April 25, 2005 Share Posted April 25, 2005 Nah mate. The exhaust manifolds are mega dollar Kaminali's. They are so wicked combined with my custom exhaust with zero backpressure. HKS dumps, HKS 2 x 70/85mm stainless front pipe then 4 inch Magic cat (get one - they flow 750 cfm), 90 mm rest of the way with NO RESONATOR to a HKS 95mm/120mm muffler. It's way better than the Hi power HKS setup. I had this set up on std turbos bar the cat and manifolds. Changed to the manifolds and within 5km of driving the car the front turbo violently snapped the wheel off at only 1 bar at 3000rpm! Seriously these manifolds made the world of diiference, if you look at the exhaust flange for the turbo - there's about 50% more air hitting the exhaust wheel. I chaged turbos not long after so I've never driven with the stock manifolds with GT-SS turbos.Never driven any other modified GT-R's either but I am just saying what actually happens in the car. It's an absolute animal off the bottom. I've G-tech it and it does 0-100 in a best so far of 4.11 seconds with ceramic button Xclutch.The ball bearing nature of the GT-SS turbos really are that good.You spin stock turbos with your fingers, they stop very quickly(second or so). My GT-SS turbos keep spinning for about 25 seconds and the wheels also weigh less than stockers. When the engine is revved (Stationary)to 4000rpm or so you can actually HEAR the turbos spooling down for about 40 - 50 seconds through the exhaust or the air cleaners. I've seen another car with 2530 turbos hit 20psi by 2800rpm with the RB30/26 combo to answer the 3 litre question. Also that link with the reference to the N1's I've held the roller N1's(I nearly bought them) and it definatly has a big .48 on the exhaust entry. Look I'm not a big net surfer and jump on forums bugger all. This is all just from modifying my own cars and what I've found out whilst doing so. Have u got a dyno graph showing power and boost pressure??? Link to comment https://www.sau.com.au/forums/topic/71152-60-comp-64-turb-gtr-turbos-power/#findComment-1317709 Share on other sites More sharing options...
BK Posted April 25, 2005 Share Posted April 25, 2005 Have u got a dyno graph showing power and boost pressure??? It's only ever been dynoed when I bought it in Melbourne at 224.5 kW at the wheels at 1 bar. Thats stock turbos and a slipping standard clutch. Mate this is Alice Springs. Nearest 4WD dyno in Adelaide 1500km away. Only 2WD one in town here at Street Torque but I'm not running an R33 GT-R V-Spec on the 2WD. It kills the transfer case, I don't like dynos at the best of times. Anyway what's so unusual about what I'm saying. Look at 400kw GTR's post in this section and he has GT2530 which full boost at 4000rpm and GT-SS turbos are way sharper than those but are limited to 1.6 bar max. Further mods include Blitz LM vspec intercooler (old style 600 x 300 x102) , Trust remote oil cooler, 1260 kg ceramic 9 button Xclutch + lightenied flywheel, reset valve clearance, oil separator kit, Kevlar timing belt, Tomei 1.2mm head gasket(8.7:1) and steel intake/exhaust/throttle gaskets, HKS wastegate actuators, the exhaust stuff and the STANDARD COMPUTER-NEVER TUNED. Car has had running air/fuel analysis on road through rev range and is still rich at around 10.1:1 at full load up to 8000rpm(remember NT- 10kms from home and theres no speed limit and the roads are good enough to it). Nothing tricky just a turbosmart boost controller because they're always guaranteed to work properly. The car is ridiculous for the street it really is and 180km/h in 3rd gear(speed limited) feels like 90km/h in a VX Clubsport. GT-SS turbos would spool up at 2500rpm on any good 3L(RB30's aren't that great). My Supra spools up a To4E(which is a decent sized turbo and plain bearing) to 1.2 bar at just below 25oorpm and does 280km/h. Link to comment https://www.sau.com.au/forums/topic/71152-60-comp-64-turb-gtr-turbos-power/#findComment-1317837 Share on other sites More sharing options...
JAGR33 Posted April 25, 2005 Share Posted April 25, 2005 BK - That's very impressive, 1.3 bar at 3500rpm with GT-SS's on a standard RB26!!!!! Also you are still running standard ecu????? Also, ur GTR can be tuned on 2wd dyno, just take out the front driveshaft.... Just have never heard of anybody achieving such boost at those revs, can anybody else here running GT-SS's confirm this???? Surely there must be quite a few GTR's getting around now with these turbos??? If so please comment..... Link to comment https://www.sau.com.au/forums/topic/71152-60-comp-64-turb-gtr-turbos-power/#findComment-1317869 Share on other sites More sharing options...
BK Posted April 26, 2005 Share Posted April 26, 2005 BK - That's very impressive, 1.3 bar at 3500rpm with GT-SS's on a standard RB26!!!!!Also you are still running standard ecu????? Also, ur GTR can be tuned on 2wd dyno, just take out the front driveshaft.... Just have never heard of anybody achieving such boost at those revs, can anybody else here running GT-SS's confirm this???? Surely there must be quite a few GTR's getting around now with these turbos??? If so please comment..... Look at Tom's car from BD4's in Zoom 86-mines very similar bar suspension and ECU(I bought all the HKS stuff bar turbos from him). Yeah I think I'll wait to go to Adelaide and get a Power FC installed from people who know how to tune them. Power I would hope at 1 bar would be 280-290rwkW and hopefully around low 300's rwkW at 1.3 bar. Keep you posted but that's pretty much as far as it goes with this car.(Unless I kill a motor or gearbox- then it's HKS 2.8L for $9000 and a OS giken box for $5000.) I'm getting an itch for another Supra but with twin GT2835's. I love Toyota's at heart but GT-R's are just such a complete package. Link to comment https://www.sau.com.au/forums/topic/71152-60-comp-64-turb-gtr-turbos-power/#findComment-1319273 Share on other sites More sharing options...
Rowdyr32 Posted April 26, 2005 Author Share Posted April 26, 2005 How do you tell what trim wheels are in the turbo? What do the stock n1 wheels measure or is it the shape of the wheels? Some people have these turbos rated at 350-400hp. How do I know if mine have different wheels because there is no shaft play at all. Link to comment https://www.sau.com.au/forums/topic/71152-60-comp-64-turb-gtr-turbos-power/#findComment-1319291 Share on other sites More sharing options...
BK Posted August 31, 2005 Share Posted August 31, 2005 Car finally tuned with Power FC + Pump/700cc's. Stock cams, Fidanza cam gears set at 4deg adv.inlet/2deg ret. exhaust and still 1.3bar(19psi) through fc boost control. 330kW at wheels from the .42 comp/.64 turbine GT-SS turbos. z32 meters also now used. Idles like factory.(made as high as 380kw with more boost and different cam gear settings but detonation on PFC near 55. Now at 35 at max.) Link to comment https://www.sau.com.au/forums/topic/71152-60-comp-64-turb-gtr-turbos-power/#findComment-1555713 Share on other sites More sharing options...
R31Nismoid Posted August 31, 2005 Share Posted August 31, 2005 Jack... talk to "you know who" man. He's done a number of cars now with them They start spooling under 3k... ~2800 i think was the comment on the dyno/4th with 1 bar well before 4000rpm, they are what im going to use among other bits and pieces. Very responsive on street 380rwkw out of GT-SS on pulp, slightly ambitious there i think, they havent got the top end 2530's have Link to comment https://www.sau.com.au/forums/topic/71152-60-comp-64-turb-gtr-turbos-power/#findComment-1556044 Share on other sites More sharing options...
NA_R33 Posted August 31, 2005 Share Posted August 31, 2005 My 33 GTR Vspec hits 1.3 at around 3500 revs on stock manifolds, has a mines computer, fuel reg, hks stainless dumps, CES tuned length front pipe, highflow cat, into a hks super drager exhaust with the resonator removed. Its also for sale makes 250kw's at all 4 running very rich and the mines ecu is untunable. Link to comment https://www.sau.com.au/forums/topic/71152-60-comp-64-turb-gtr-turbos-power/#findComment-1556117 Share on other sites More sharing options...
Mik Posted August 31, 2005 Share Posted August 31, 2005 My 33 GTR Vspec hits 1.3 at around 3500 revs on stock manifolds, has a mines computer, fuel reg, hks stainless dumps, CES tuned length front pipe, highflow cat, into a hks super drager exhaust with the resonator removed. Its also for sale makes 250kw's at all 4 running very rich and the mines ecu is untunable. <{POST_SNAPBACK}> What sort of turbos does it run? Link to comment https://www.sau.com.au/forums/topic/71152-60-comp-64-turb-gtr-turbos-power/#findComment-1556239 Share on other sites More sharing options...
BK Posted September 1, 2005 Share Posted September 1, 2005 (edited) Jack... talk to "you know who" man. He's done a number of cars now with themThey start spooling under 3k... ~2800 i think was the comment on the dyno/4th with 1 bar well before 4000rpm, they are what im going to use among other bits and pieces. Very responsive on street 380rwkw out of GT-SS on pulp, slightly ambitious there i think, they havent got the top end 2530's have <{POST_SNAPBACK}> Slightly ambitious ? I wasn't expecting anything. I was glad to see it break 300 kw. But they seem to out-perform 2530 in response and top end and be closer to the 2540 mark in outright power for the same boost(GT-SS stop at 1.6 bar,2540's at 2 bar). They are rated identical output to 2530's and were only releaed last year being better in design. Don't worry, a lot of people there thought it had 2530's or 2540's on the dyno tuning. Doesn't matter I'm happy with the output now. Power will be capped at that. Edited September 1, 2005 by BK Link to comment https://www.sau.com.au/forums/topic/71152-60-comp-64-turb-gtr-turbos-power/#findComment-1558491 Share on other sites More sharing options...
