About 2 issues ago HPI mag did a DIY install guide on these for a R32. Its not very hard. Just get local suspension shop to do final adjustments
PS - is the caber top adjustment the only difference between the two models, other than that they are same? They lok diferent in pics.
Cheers
guys just to clear things up R32s cant have the camber adjustment.
i dunno about other models though.
i have these in my car and i got the pillowball ones which are meant to have camber adjustment but not for the R32 :rofl:
lol get em while they are hot... just a figure of speach i hope! whats this about cant get the camber adjustable for a r32? I already have coil overs on my 32 GTR but not camber adjusting ones. So i am looking for some so please explain???
as far i i know they all come iwth camber adjustment
will confirm for the r32
oh yea and it was a figure of speach
cheers pete
The HR32 Suspension geometry does not allow
camber adjustment on the shocks as does MacPherson strut. -S13/14/15
SO no camber adjust shocks for Skylines!
You can adjust them, just with diff hardware.
i have an R32 HCR32 GTS-t RB20DET.
i have been looking at getting the HR coilovers. but what do u mean about the camber adjustments ?
And shipping does this include shipping ?
i live in syd.
Mod ur car will do it $1,599 free shipping for SAU members.
no doesnt include shipping
bt im 1000000% positive shipping wont be 110 dollars so you can bet it will be cheaper
however if you dont know me i understand your desire to pay more :)
speak to any of the people who run SAU in NSW im sure they will vouche for how dodgy i am :P
im only farmilure with the s13 stuff cause i use it on my r31(with a conversion kit)
but if skylines r32 or > dont have the camber tops its proabably best to buy the cheaper ones
pete(will find out about >r32 tommorow)
A few questions, what sort of delivery time do you expect from time of payment.
And as they arent adjustable camber because R32s like R33 used wishbone front ends, is it possible the cheaper HS uses the std rubber shock top, where the HR uses billet tops with pillow nall mounts?!?!?!
Since they supply the same spring rate im tempted to go for the HS and buy some alloy tops seperate, but i suppose it depends if the HS come with any?!?!?!
Outside that i reckon im about an 85% chance of giving the HRs a go:)
Higer spring rates and adjustable rebound and ride height...outside of that i may be able to let you know in a week or two, as im looking at upgrading from my Whiteline kit at the moment to something a little harder in the spring department.
i'd love to as i've had my eye on these for my 33 for a while now, unfortunately the cash for them won't be in my grubby hands till tax time so i'll have to pass, shame.
good luck with them. be interested in hearing the results of installs.
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
