  • 2 months later...
  • Replies 44
I used the cut diagram in the first post but the holes are way off, is this for a r32 4door because mines a 2dr.
I've checked the black dots on the paper cut out under the PDF piece and they are right on the money but for some reason on the car they don't align with all the holes.
Any help appreciated.
Hi,
Definitely for R32 2 door (1989)
To be honest, I have not tried printing it out, as I own no printer, but somebody else said that they had used it successfully above.
Have you measured all the dimensions on your MDF to ensure that each of the measurements is the same on the diagram?
Hi,
Yeah i made sure all the lengths were correct but the holes didn't line up 100%.
Probably just a off centre drill (didn't have a drill press) but i worked it out.
Thanks.
Hi,
They are slightly off but not that far. Very easy to fix if you just counter sink the screws as well :uh-huh:
Although having said that i couldn't get over the difference for the 2door install to the 4 door install.
WIll post up pics and info in another thread so im not hijacking Predator's thread :innocent:
Cheers B
  • 8 months later...
the old speakers have plastic spacers that come out...you're removing those and fitting these wooden ones of about the same thickness.
The skins go on, and you wouldn't know that I had 6" speakers in there. The skin is screwed to the bottom of the door as per normal, and the bottom right toggle is still used.
Pics would only show it looking as per factory with the skins back on.
  • 2 months later...
  • 1 year later...
  • 4 weeks later...
I used this yesterday to get my install done. It's all ended up working well but the diagram needed some modification. I think the mounting holes for the OEM speaker bracket are done after manufacture by whoever is screwing it in, so they all end up in a slightly different place for each car. Either way, the diagram really helped so thanks a lot.
  • 11 months later...
sorry to re-bump and old thread but the links are broken again
can someone pm me them please?
also is it worth doing this or modify the stock bracket to accept some 5x7's? i've been doing some measuring and i reckon with some spacers they'd fit (not sure about door skin clearance)
  • 2 months later...
  • 1 year later...
thread revival..
does anyone have an after-shot of 6.5 splits into their r32 doors?
i noticed from the sticky that:
"R32 - 4x6" front, 6.5" rear (Plate in front doors will see a 6" in there)"
just wondering how much it will effect the factory grill with that extra 0.5", I dont want to alter the look of it, not keen to hack up a chunk out of it to fit the 6.5's otherwise ill leave them as is.
would i be better off with 6"?
(tossing up between 6.5 alpine type R splits or 6" JL C2 splits)
Regards,
Yao
Edited by okooko
Well considering there is no Edit button that I could see here are the photos of the template in use. I haven't screwed the speakers in yet as I haven't wired up the car yet but everything seems to fit fine. Sorry about the crap quality, was taken on an Iphone 3g. As others have said some of the screw holes don't line up, I was able to line up the top 2 holes but redrilled holes for the bottom 2 screws. I'm not very good with woodwork so this is just evidence that anybody can make and install these pods. As mentioned earlier when printing out the template do it in Illustrator and make sure there is no scaling on and if your printer is like mine and doesn't print the bottom line don't panic because the diagonal lines going to that part work out to be 70mm to the edge of the paper so just bust your ruler out and line up the diagonal line and finish the line to the edge of the paper.
the door trim sits tight against the speaker using the 12mm MDF but there was no need to try and force the trim on. Also you have plenty of clearance for the power windows as well. This is installed on a 93 GTS-T 2 Door. No modification to the "Active Speaker" grills needed either.
Edited by Triptych
I'm beginning to think that there are 2 types of 2 door R32 front speaker hole styles. The template and it's holes were nothing like mine (R32 GTS-T 1990). I created my own template and here is a pic for reference and comparison with predator's. Also I am pretty sure i have the same door style as raz0r$harP.UK as stated in post #12. I used 12mm MDF from Bunnings and the door trim will not go over it.
Lets see if we can work out where things are going wrong for some people. Did early and late models come out with the"Active Speaker" grills because I thought I saw somewhere that early models didn't have the Active Speaker but of course I could be wrong.
If somebody who couldn't get this template to work could upload their stock plastic speaker surround it might help us out a little bit more. Now the holes were not perfect on mine either I could get the 2 top holes to line up but had to redrill the bottom 2 (was only a few mm off) but as I said I had no issue with the door trim. You may have notice how far back I countersunk the screws on my pod but that was mistake by buying screws that were to short.
Here are the stock plastic pods from my 93 R32 GTS-T 2 door with active speaker grill.
Front
Back
Also don't forget to countersink your screws as well because remember you adding a few more mm's on top of the 12mm MDF leaving the screws sitting above the wood.
[EDIT] After reading through the post again maybe it isn't a year model difference. Hmm I wonder where things are going wrong for some people.
Edited by Triptych
Well, i was measuring and all yesterday. My speaker didn't actually fit in the speaker door hole (hole was cut too high i guess), the top bit of the new speaker was interfereing with the door skin cave in (as it added extra mm). Measured the gap in the cave in and it was roughly 9mm, so the 12mm would've been hitting/touching the door skins anyways. I actually have screws that are too long lol.
Yes I do have 'active speakers' and yes the plastic OEM moulds look exactly the same.
Edited by TyresBro
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
