  • Replies 46
Dude, I will be getting Falken Azenis for my 18's i think.
I run 235/40/18 and 265/35/18 , not sure if they come in 265 (or if i want them in that size - my car is pretty tail happy) but i will definately get them on the front.
Falkens are good but i find they wear out fast, the falkens on the front of mine are hell grippy but i need to replace them and at $505 a tyre you could have guessed im not using them again. I just put Kumo's on the back, they arent as good in the dry but they are the best wet tyre ive ever come across and i used to have the specific wet tyre off falken. Plus they were only 285 each bargain!!:uh-huh:
Originally posted by DentonR33
And your happy with them ONARUN?  Good grip in dry/wet>
What kinda kms you get out of a set?
i haven't gone through a set yet as i've only owned car for 1.5 months before accident. the deal with them is they grip and keep on gripping until they reach their absolute limit when they let go. you might say all tyres do that and you would be right but this set gives you no warning (screech) before they let go. pretty good in the wet too. most everyone you ask will talk them up and the reason is they are pretty much the best tyre you can get for under $250
kms/set depends on your driving habits as always;)
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
