Anyone know if it's the same situation for an R33?
My brother has the GTR bonnet on his 32 GTST and the weight difference between the two is phenomenal.. btw he has a grill cable tied in the space..
  • 2 years later...
you dont need GTR headlights all the time, as some already have the mounting points on them. I would even say GTSt and GTR headluights are the same....
my gts-t type m - mspec projector type headlights are exactly the same as gtr headlights
Bumping up an old topic
Gona try this on the weekend anyone had any trouble with doing this??
i had a thread about the whole front end conversion that i did a few wks go. u an find it in my profile.
all the info u need is there, i would suggest going away from the way this topic has got around the latch situation. the way i did mine is the cleanest, tidiest and the easiest way of doing it.
find yourself a r32 gtr front "L" piece rad support (i pictured one in my thread) and this simply bolts in place of the gts-t item and your gts-t latch assembly will bolt onto that.
before you bolt the latch assembly on however make your way over to a simple vice and make a few bends in the "hand lever" so that it fits nicely with the grille and your in...
anymore questions have a look at my thread or pm me
ben.
  • 1 year later...
  • 1 year later...
This is not nice work - it is structurally unsound and lacks rigidity.
It should not be followed.
Nice work man. She's looking great!
The lightweight GTR bonnet is the goods and no it does not make you a ricer, because who can tell the difference? :(
I wonder what the weight difference is that your now saving..
Leaving the Centrebolt off or redrilling will weaken the latch assembly.
Wedging the Bracket on top of the bottom anchoring bolt cannot possibly be a solid fit.
This approach should not be followed.
Why? Because the Bracket is made from two pieces, 2 x spot welded at the factory. The Centrebolt and the two bolts securing the Latch give structural rigidity to the Bracket and take up the loads, along with the spot welds. These three bolts are stronger than the two spot welds.
This necessarily relies on the the bottom bolt to properly secure the Bracket.
______________________________
This is mainly for roy and blck32, but others may find it useful.
Here are pix.. hope u follow.
The bottom of the bracket on the bottom of the radiator support, I undid, and shoved up, whilst putting the bolt back in. So the bracket basically sitting on top of the bolt.The washer on the bolt wedges it into place and is a very solid fit.
Spacers/washers basically fit behind the top radiator support there.. allowing the bracket to be moved back about 1cm from the support. Those bolts were a bit big, but all I had sitting around that would suit at the moment.
I had to remove that centre bolt and just left it like that. Its not massively important to the rigidity.. but you may wish to redrill, and the refit bolt if you like.
finished result..
p.s. don't whinge at me for putting on a GTR bonnet! my gts-t one came from japan badly faded and with a dodgy chip in there, and dented.. to fix would require new GTS bonnet (~$300) + painting ($300) = $600.. I only paid about $100 more to get an aluminium bonnet, in my car colour, that should provide a bit better airflow to the engine/radiator at the same time. The fact that it happens to be a GTR one that is what it is..
    • I don't know if you can disassemble the thing and put it backwards for different ramp rates. They're both "2 ways" or both "1.5 ways" because well, 2 ways and 1.5 ways are the same 'thing' I do not know for sure, but I believe the 38420-RSS15-B5 is the 1 way, and 38420-RSS20-B5 is the two way. In other words, I predict Nissan considers this: to be a 1.5 way. No idea what actually happens when it arrives/you disassemble it. It would be an excellent question to ask Nismo directly! I somehow doubt you will get an answer though, I feel you would be the first person to document what you encounter when you open the box and the internet would be grateful.
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
