Semi slicks dont grip in the wet due to tread block design (well they do, but not as good as normal "high performance" road tyres). A true semi slick (R compound) will be dead on you within 5000kms as well.
Besides those two points, check out the suspension and handling section, lots of threads in there on tyres :)
https://www.sau.com.au/forums/topic/72190-tyre-choice/#findComment-1329062
I post here because its better to get opioon off ppl who i know.  The Falken Azenis ST115s i am pretty sure arent made in 265's
Well thanks i think i will ask around for fedrals see what happens.
They 'were' made in that, cause i have them in 265/35r18. Not sure whether they are any more, however my mother checked prices for me one day, and somewhere assured her they could get them, at $490 a corner though :rolleyes:
Going to try out Firenza this time around, Ash who some of you know has said good things about them
https://www.sau.com.au/forums/topic/72190-tyre-choice/#findComment-1330717
Highly suggest Falken Azenis ST115s. Plenty thumbs up.
Yeah, theyre not a bad tyre, have a couple of dramas with them tho, when i did a motorkhana on them, the car was front wheel sliding at times, i thought that shouldnt happen on 235's,
other then that, they are a good tyre, i have no trouble smoking them, but when you want them to grip, they do, except for some acquaplaning in the wet (255's but so its understandable)
https://www.sau.com.au/forums/topic/72190-tyre-choice/#findComment-1335730
I had Nexen N2000's on the back of mine for a while, they're not a tyre that I'd reccomend to anyone that likes grip
They'd be awesome for drifting though :(
I've got Vredestein Sportrac 2 tyres on the front of mine, brilliant tyres
they stick like shit to a blanket, even in the wet (2 huge ass water channels might have something to do with that)
http://www.vredestein.com/autobanden/Main....&BandTypeID=471
And currently I have Bridgestone Turanza ER30's on the back, which were good when they were new.....
https://www.sau.com.au/forums/topic/72190-tyre-choice/#findComment-1336581
I'll second the vredenstein sportrac's. I have them on the front of my car and no matter how hard I throw the car into a corner, the front will not slide. Also under really heavy brakeing they have great grip so won't activate ABS unless you are literally standing on the brakes.
https://www.sau.com.au/forums/topic/72190-tyre-choice/#findComment-1336606
Shaun, there is one high performance tyre that I would recommend in that size Falken FK451's, they're not to pricey but they are as good as youll get for street performance...
I got Frink 2 of them in 265 40 R17 for about 90 cheaper per tyre than retail, I know I guy.
Let me know if you want me to get you a price.
https://www.sau.com.au/forums/topic/72190-tyre-choice/#findComment-1340038
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
