I purchased an R33 GTR Cooler and an East Bear A31 GTR Cooler Piping Kit. I reckon paying the $500 for the GTR cooler is a better investment than $300 on a Hybrid Copy China Whistler core.
JK
lol, its funny you say that.
i have one of these hybrid copes. and in terms of cooling efficiency i think it is actually quite good... but i have noticed that it is actually whistling!
Is there a known method of stopping this. it really is quite annoying.
Cheers.
I dont think there is much in it between the two coolers but youll pay a little more for a GTR cooler and they will both work well. I think youll have to be more concerned with organising the piping for the GTR kit you ll prob have to get it made up, where as the Hybrid kit comes with everything all together. The way the inlet and outlet pipes are designed are different. The GTR cooler inlet and outlet fold back a little from memory where as the Hybrid just stick straight out from the cooler. This something you will have to take into consideration when organising the piping kit. As for the whistling, not all of them whistle.
  • 3 weeks later...
appoligies to dig up an oldish topic, but it had just come to relevance for me
I have a R33GTR intercooler sitting about, it is slightly damaged. Im not sure if i should go a genuine hybrid or stick with the GTR cooler. Big pickle im in. do real hybrids whistle? Any furthur opinion, but more welcome- evidence one is better than the other?
go the GTR cooler as it will flow alot better than any Hybrid cooler (unless its very damaged of course!)
ahhahahahahahahhahaha!!!
do you really think you would notice the differences between a gtr cooler and a hybird one?
How can anyone turn away a hybird cooler it cost around $200-$300, i havnt had any problems with mine and it flows good :) u pay that or more for a SECOND HAND gtr cooler
Im not sure personally but this is the general idea ive noticed around the forums.
A REAL Hybrid cooler will cost u similar to what a GTR cooler will cost, a China cooler may whistle which piss's ppl off!
But im glad u thought it was so amusing...
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
