I can recommend a GREAT Fiat, Lancia and Lada workshop in Market St :)
But for an S15: Chasers is close by - in West Melb.
They are on Dynon Rd now. Head around past Telstra Dome - 10mins away.
From their website: http://www.chasers.com.au
ph. 0433 184724 or 0438 668880
Unit 4, 440 Dynon Road
West Melbourne
Yeah call Chasers for sure. Their new shop is 440 Dynon road which is the contination of Spencer Street. Dyno went in yesterday. Call Benny on his new number 0416009785.
Tell him Jevan from the Skyline forum sent you down and he will look after you!! Check out the Silver R34 GTR that is in the shop at the moment!! AMAZING
Hehe - maybe. But from the little I know about the car and it's future intensions it's a "go in a straight line" project. And from what I hear it's planned to be a monster. I'm looking forwards to seeing the project finished.
So in another twisty competition it still may get owned no matter what is done to it. Especially if like the last time it tries to do circuit work on Nitto's LOL.
Chances are if the last DVD was a 1/4 mile comp I would have finished 3rd - not 1st anyways. So it's horses for coarses. I was actually a little suprised with the cars that turned out truth to be told. It was a track challenge and other than my car the Hypertech S15 was the only other car actually set-up for track. The others were either drag or drift cars.
I have been talking to Simon about Serious Performance 9 DVD and doing a top speed challenge. In that the Silver GTR would probably own me - but I think the Ice Supra would have us both. LOL
I want Luffs job, tour around punting other ppl cars:( Luff Snr thrashed the beejeezus out of my old dear in front of the Serious Performance cameras and the footage never saw the light of day:( Goes to show other then me noone is interested in little 32GTSTs:)
When i drop my car off Troy i would like some rockets pls, just as long as they dont stuff up the paintwork...picking bonnet up this weekend, will call you next week when i know when ill be back in Melb:)
In the middle of building a new bake oven at the moment....you might get the first job to roll out of it...you know the one where you bust a full champers bottle oven it :(
In the middle of building a new bake oven at the moment....you might get the first job to roll out of it...you know the one where you bust a full champers bottle over it :(
In the middle of building a new bake oven at the moment....you might get the first job to roll out of it...you know the one where you bust a full champers bottle over it :cheers:
No way man! You can *accidentally* install Troy's carbon bonnet on my thing if you want to :)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
