i just got a new map sensor and harness for my power fc because the old of broke (long story)
any ways i got a new map sensor and harness for it but the plug does fit into the power fc
just need to know is there any way of geting it to fit? like cuting the wires and changeing the plug?
if so where can i get the plug and how do i know which wires go where
because it only has 3 wires in the plug RED BLACK GREEN
IF ANY ONE OUT THERE HAS A POWER FC PRO USEING A MAP SENSOR I NEED UR HELP
or can i just buy another harness if so where from? Ill buy another map snesor if i have to as well !!!
https://www.sau.com.au/forums/topic/73268-apexi-power-fc-pro-help/
Sorry mate but I've got a Pro and it's AFM only, The only bit extra is a Launch control and Spark cut instead of fuel cut for the limiter
Taken from various websites -
APEXi Power FC D-Jetro
The D-Jetro Power FC units carry the same functions as the regular Power FC units but do not require the use of the factory standard air flow meter and use a mass air pressure sensor. Apart from the unit itself, use of the D-Jetro units requires addtional parts that vary depending on the model.
Power FC Pro Spec.CPU (for DRAG)
Only available for some car models, the Power FC Pro Spec.CPU has been designed for drag racing use. These units have two additional functions over the regular units:
Ignition cut used for rpm limiter - Regular Power FCs cut fuel feed when the preset revolution limit is reached. At high rpm, there is the possibility of knocking when the fuel is cut in high powered cars. The Power FC Pro Spec.CPUs cut ignition at the rpm limit to prevent the knocking that could potentially destroy the engine.
0km/h rpm limiter setting - Allows for the setting for an initial rpm limiter that is active whilst the car is not in motion. This allows for mainting a rpm level for consistent launches.
I've never found any info about Pro ECU's being MAP capable when I was buying mine.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
