Just replaced mine (32 gts-t)
DBA slotted were quoted around $200 a disc... I was thinking this was going to be costly exercise but needed it done as my rotors were warped from when the car was imported.
I ended up with ventilated Brembo's for $65 each! (new). I replaced the front rotors only and put new brake pads on. Works a treat.
https://www.sau.com.au/forums/topic/73299-new-rotors-r32/#findComment-1356783
thanks guys, this is what i was after, i bought a set of DBA slotted rotors for the hr30 about 18 months ago and they were 340 each, the first set they had made for a r30 skyline, i've now upgraded the fronts to r32 gts-t's 4 pots and rotors and was hoping that new rotors would be alot cheaper.
DBA will make a set of r32 rotors in the 4x114.3 for a bit more $$ wont they?
https://www.sau.com.au/forums/topic/73299-new-rotors-r32/#findComment-1356876
Is it hard to replace front rotors, and is there instructions online?
Thanks
al
https://www.sau.com.au/forums/topic/73299-new-rotors-r32/#findComment-1364729
I put DBA rotors on the front and some protec cheapy's on the rear as I was unable to soruce DBA rear rotors for the R32 anywhere in Adelaide. :)
From memory the front DBA rotors varied in price massively.
Cheapest place to buy DBA rotors from In Adelaide are Motor Mates.
Where did you source yours from Pablo?
https://www.sau.com.au/forums/topic/73299-new-rotors-r32/#findComment-1365047
ended up getting quotes, from autobarn for DBAs and glodal auto spares for RDA,
the fronts with DBA were 325 slotted and with RDA it was 283 for the slotted, the biggest difference was the rears for my hr30 were 269 for the DBAs' and 135 for the RDAs' both slotted
https://www.sau.com.au/forums/topic/73299-new-rotors-r32/#findComment-1365288
It seams the smaller houses will get these parts cheaper as they want you to ome back and use their services, so shop around. Perth Brakes Australia is one of the bigest suspension and brake places in WA and they wanted $2656 for each rotor. HA? So go see if there are garages that tune and race their cars as they will be more connected with manufacturers and sponsors at the same time.
Al
https://www.sau.com.au/forums/topic/73299-new-rotors-r32/#findComment-1365361
$65? what the? where from mate?
https://www.sau.com.au/forums/topic/73299-new-rotors-r32/#findComment-1378375
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
