  • Replies 94
Hey Guys,
if anyone wanted to come along and show off your awesome cars, (they are all really really hot) you are more than welcome, the more the better, i'm thinking of getting CD's burnt and playing the same CD's in all the cars (effect) this is going to be great, you guys will be the talk of the night. i'll organise a couple of cartons for your troubles.
https://www.sau.com.au/forums/topic/73343-help-me/page/3/#findComment-1353243
Hey Guys,
Yeah let's turn it into a skyline cruise!!!!!!!! It is on a thursday night after all!!! We can meet up with the white skylines, deliver the "goods" cruise around the city for a bit then cruise up the coast?
https://www.sau.com.au/forums/topic/73343-help-me/page/3/#findComment-1356083
Alright, so final numbers, everyone who wants to come along can you just reply in a personal message, just so i can get numbers. also we were thinking of meeting at a park close to the venue so i can give out the CD's and organise colour orders. i'll post any other arangements ASAP.
Thankyou all so much, you're the best.
https://www.sau.com.au/forums/topic/73343-help-me/page/3/#findComment-1358778
