Ok I posted a thread here about one of these but no one had tried one so i bought one to see how it goes.
I have previously tried 3 boost controllers and this is equally as cood as the Electronic boost controller i had.
Greddy cabin pnumatic bleed valve. spiked like shite and wasnt too good.
Atomic GFB bleed valve. was a little better but still spiked.
GRID single stage electronic boost controller. it was very good and did not spike and it was very accurate.
The one i just bought is a mechanical/pnumatic controller and is well made.
i drew a little paint sketch to show how it works
It builds boost INSTANTLY because the ball does not let any pressure through preventing wastegate creep. Then when it reaches the desired boost level it opens and holds the boost within 1 psi of the set level.
I set it to 12 psi and it does not spike at all! but it does bleed off 1 psi at very high rpm.
The car is now super responsive because it gets to 12 psi alot quicker and holds there.
I bought it of ebay and i suspect the guy who sells them builds them but they are very well made and work incredibly well
Just thought i would post my results for those who are looking for a boost controller. Sometimes car accessories are really cheap on seasonal Big W Catalogue.
UPDATE... this is for the 100's of people wanting to know how to install one of these buggars... Check (if you live in usa): Kroger Weekly Ad, or Myer catalogue.
R33 INSTALLATION DIAGRAM
Edited by CEF11E
  • Replies 1.8k
Posted Images
just gave the car a good hard test and i have been able to get the boost to hit 12psi at 2600rpm!!! and it stays there untill 6400rpm and then drops about 1psi close to redline.
I have an auto and the car just feels so much better to drive. there is tons more torque down lower in the rev range maknig the car more enjoyable to drive.
i cant belive its the same engine and turbo because it boosts so much faster.
at 4.5 psi (stock boost for my car) without the controller boost starts to build at 2600 and full boost by 3100~3200. and the car feels very laggy. The car is a nissan gloria and is a cruiser designed for smooth power delivery.
with the controller boost starts at 2200 and full boost (4.5 psi) by 2400. this means it is stoping wastegate creep very well. it also means my stock actuator sucks!!!
so not only can you use it to deliver more boost you can also use it to deliver boost much faster.
Its funny how sometimes the simplest thing gives an excellent result. i thought i would give this a try and if it was crappy i was going to build the jaycar boost controller but for 20min install and $22.50 i got a result i am very happy with!
I would say i just got the cheapest power gain ever prob about $1 per kilowatt!!!
:rofl:
yep exactly... its a bit at a time process.
first you leave it completly open giving you normal boost level
(opposite to other bleed valves) with normal bleed valves the more you open them the higher boost you get.
take it for a spin, make sure no hoses have come loose and boost builds normally.
raise boost by tightening the allen key down 1/4 turn, go for a drive. repeat untill you have reached your desired peak boost.
once it is acheived tighten the locking nut in place so it stays at that boost level.
I've just picked one of these suckers up. :D
It actually works a little different to the one I had previously.
This one doesn't appear to bleed any boost at all but use a variable pressure on the spring.
The one I tried had a preset pressure on the spring and ball then would bleed boost in order to get the required boost. :D
a question i have an external gate now it has 2 nipples on it now i just got one of these boost controllers and i know it has to go some where so where and what nipple does it go on
bottom at the moment is connected to the inlet manifold so do i tee into that line with the boost tap the run the line from the tap to the top of the waste gate???
I've just picked one of these suckers up. :P
The one I tried had a preset pressure on the spring and ball then would bleed boost in order to get the required boost. :(
So you're happy with it for the money?
It took 7 days for delivery including the 1-2days it took for my online banking direct deposit to clear.
I've attached a few pics of it. Initial inspection of the spring and ball was its rather decent quality.
The spring is very much so decent quality and has a heavy duty feel.
I'll hook it up within the next day or so and let you all know how well it works.
In parts.. You can see the small hole that stops the pressure being trapped between the ball/spring and the actuator.
Really for $22 its worth it PROVIDING it controls boost. lol I'll find out.
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
