Yes CEF11E is correct. It was difficult to tell by the pics but it appears that the nit is connected corerctly to the actuator but cannont clearly see if you have other barb connected to compressor side of turbo. I believe its in the way it is installed that is the problem, perhaps you have the wrong line at wrong point..
Mark
  • Replies 1.8k
Posted Images
From the picture i can see the solanoid is still connected. I would advise to disconnect it. As i have never seen under the bonnet of an r34 i cant see where all those connections are going.
if you wanted to test it and isolate the the problem.
1. look at the turbo compressor housing. these should be a hose coming off it connect this to the BOTTOM of the boost controller and leave the other side connected to the actuator as you have it.
ok so controller to wastegate actuator con is ok.
where the T piece is the are 2 hoses con. The top one cons to the bottom of the solenoid.
The bottom T piece con connects to the turbo pipe (pipe beneath air intake pipe bout the same diam).The other pipe not con to the T piece comes from a silver pipe below and cons to the top of the solenoid.
The 3 pipes are all within that black platic sheath secured by plastic tie.
So with this in mind u say:
1. leave con from control to wastegate.
2. Disconect the top T piece con that goes to bottom solenoid con.
3. Connect bottom (thicker) T piece con to the controller directly (the one that goes to turbo pipe)
4. Disconnect the other pipe (from silver pipe below, not con to T piece) that goes to top of solenoid.
So basically take solenoid out of equation. Is this going to cause any problems? Thanks all for your patience just want to verify before I go out and do this. LOL I'll get there one day I hope!
lol mate i can make one for $9. u can get everything u need from a good hardware store...
Finding the components is the easy part making them to precisley control boost is by far something else. A number of people have tried to copy without success and caused damage to engines.
If I give you all the materials to build a house can you build it right???
There is always someone that likes to be a goose.....
Mark
As other guys have said boosts earlier and holds very well and holds it in a stable manner. Basically, even on idle the boost guage does not sit near zero anymore its like 1/5 of the way up. Torque builds quickly making the turbo more usable = better average power. I only have this and K&N Panel and I've noticed a good difference in limited testing.
Working installation on R34 below. Happy to help as others have helped me, as u can see I had some dramas :rofl: But all good now. Mmm perhaps I should plug up that T piece. Next step for me is full CES Racing zorst, should get the silver service taxi moving nicely.
That would indicate you previously had a vacuum leak, idle and light throttle should sit under zero, moderate throttle should be zero plus. :rofl:
Yes could have exagerated that point in retrospect (guess i was excited at finally getting it working). I think that the guage does sit higher on idle than it used to though or am i just imaging this? Certainly easier to get that turbo whistle happening in either case. Think I might have to take it out tonight again, possibly up a few hills. All in the name of testing of course :kewl:
i still say this is THE BEST boost controller i have ever seen i cant get over it
congradulations to simark87 for the design and engineering of the product
this is my hands down the most bang for buck i have bought for the car also 100% reliable and effective and safe
so if i have dialled in 15psi or 20psi thats all im going to get no more no less no spikes no shit
congratulations!!
matt
Hi guys,
Glad you all like it.
Special for skyliners remians at $28 expresss delivered in AUS.
Just email me at [email protected] with your oder adn address, I will then send you my details and supply a ref number.
Cheers all,
You lot make me want to trade in my cordia for a skyline...lol
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
