  • Replies 1.8k
Posted Images
yeah apparently they are quite popular with 300zx guys for a long time... they apparently call them boost jets (as told to me by my 300zx owning friend after i told him i got it!)
you sure?
i thought boost jets where when they put little metal restrictors in the hose with a specific diameter...
Ordered mine.
I'll let you know how it goes in direct replacement of my GFB unit running 16psi.
The GFB for me is holding fine, but it spikes 1psi which sucks teh cok.
Let me know how you go. I've got a GFB @ 14 psi and it's holding great till redline. I do however get a 1 psi spike.
I'd be very interested to know if this one brings boost quicker. :rofl:
OK, so I fitted mine today and the boost went straight over 10lbs on lowest setting..
I put mine where the t peice is that leads off to the solenoid. Is this right?
Any ideas?
Wasn't game to find out how high it would go...
By the way, I bought my car with an upgraded FMIC, and the actuator was connected to the BOV by another t peice. Where does the actuator get its reading from in a normal R33? Before or after the throttle? I thought that it was suposed to be before the throttle body and whoever hooked mine up did it wrong.
Can anyone post a pic?
Thanks.
Hi guys,
I am giving some thought to a 2 stage but don't want to compramise on quality so it will take some thinking but I'm sure it will eventuate :)
I hope everyone is having with there new toy, and not over boosting hehe yeah right!!
I am looking at importing some intercoolers and BOV in th enear future. Keep you posted. Skyline discounts apply of course :)
Mark
simark.. the diagram on the piece of paper you sent me says i should T-piece the bleed valve back to the BOV....why? mine isn't n it still runs 14psi,
What are the benefits of connecting it to the BOV?
please nothing to technical.
The diagram is a basic explanation of connecting a BOV. Skylines and other late model vehicles have complex setups. The diagram is mostly intended for basic technology turbo charged vehicles like cordias and starions and so on...
While not a skyline expert, I would say if you are having a great result from the controller as is then don't mess with it..unless of course someone more knowledgable about skylines suggests something else..
Mark
you sure?
i am pretty sure as my friend really knows heaps of guys with 300zxs, and i actually took and showed him the device after which he told me..
i guess different people use different terminology, doesnt matter much anyway :)
Any ideas?
Thanks.
Chrissso, had a read back through the posts. There are already pics posted.
http://aus300zx.neuralmotion.com.au/index.cfm;jsessionid=3a3016b1dd91$C5$19$D?action=view&type=post&postid=242235&highlight=boost jet://http://aus300zx.neuralmotion.com.au...light=boost jet
well actually 'boost jets' as talked about in 300zx land are welding tips that they put into their boost hoses to change the time it takes for air to get to the wastegate. works well for them in increasing boost consistently
the link is from www.aus300zx.com and i know some people from there with Zed's and that is what a boost jet is in their talk...
maybe they could benefit from this as well then, Mark?
Yeah... I know. I could see what I wanted to see.
My actuator is connected to the BOV, wheres your connected?
Chris
:evil:
Edit:-
That should read " I couldn't see what I wanted to see.
D'oh!
I would have thought if you're getting yourself one of these devices, the best thing for you to do is just remove the solenoid from the equation, (why have two devices that do the same thing?) connect one end of the controller to a manifold fed vacumm line and the other
to the wastegate, then bobs your uncle and away you go.
Sounds pretty straight forward, putting my order in today, this one will be going into my rx7, we'll see how she likes a bit of extra boost :P
Cheers
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
