  • Replies 1.8k
Posted Images
Turbotech Electronic Dual Stage Upgrade Kit WITH V2 Manual Boost Controller just ordered. Really looking forward to seeing how this performs compared to my old HDi electronic boost controller. :D
Just had my V2 controller and Electronic Dual Stage Upgrade Kit (missile switch) installed today. For those of you running one, is the missile switch supposed to light up blue when flicked to high boost? It did seem to light up for a few seconds briefly then went dark. I'm not 100% sure as it's not mentioned in the instruction manual at all.
Hey guys,
Just asked this question in another thread but figured this would be a more appropriate place for it, plus might help out people in future who want to know the same thing.
Does anyone know what the quality of TurboTech's boost gauges are like?
I recently ordered a boost controller from TurboTech (after reading how awesome they were) and it came with a mechanical boost gauge.
Haven't hooked it up yet tho, wanted to know if it's even worth installing first.
Now I assume that they are not their own TurboTech branded boost gauges, that they merely on-sell another brands product packaged in with their own.
I also assume that with all the raving reviews of TurboTech's controllers they wouldn't go jeopardising their great reputation by supplying sub-par accessories; but hey, I might be wrong...
Any thoughts/opinions?
I would assume the gauge is accurate "enough" for what you're doing... I've used yumcha vs. jap gauges before and didn't see any real difference between the readings.
Being a mechanical gauge too, it's more simplier to build
Yeah fair point, reason I ask though is because I think (hope) my stock gauge is reading incorrectly. Either that or I'm overboosting.
I did the ol' solder trick to the boost sender unit and it fixed it cutting out randomly, but now that it works all the time the gauge is maxing out when boosting hard.If it does happen to be showing a proper boost pressure, this means its pumping around 14 psi!...
So I want to install the TurboTech to keep it under control but don't want a gauge telling me I'm running a safe 9psi but really I'm on 15 psi and go bang! :down:
Edited by Brad54
on a stock ECU, your motor won't go bang :)
The stock ECU detects knock and drops timing, hence the knock sensor. The only thing that would go bang is your nylon turbo made with fairy floss lol
  • 4 weeks later...
Need to give big props to Turbotech for customer service.
I have had a Turbotech MBC for a good while now and recently I lost the bolt and spring from the controller. Sent Turbotech an email on Ebay to see if I could buy the bits seperately and they straight away just offered to send them to me for free not even charging for postage. Very impressed by them
lol how did you manage to lose the bolt and spring? Was it installed in your car when you realised? :/
I had threaded it out real far to make sure it didn't make any more boost than actuator pressure on new turbo. Unfortunately didn't realise it was right on the edge of the thread. I noticed I had lost it the day before tuning the car so unfortunately was only able to tune on actuator pressure
Well, lets just say that this is one awesome bit of kit! Got it in the mail today, and went for a drive, pulled up to adjust it up a bit more, set it to 18psi and it just spools straight up to max boost and friggen sits there. Drops off 1psi at redline but that's it.
I'm am very very impressed. Throttle response is off tap. Cheers guys
  • 4 months later...
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
