  • Replies 1.8k
Posted Images
Turbotech Electronic Dual Stage Upgrade Kit WITH V2 Manual Boost Controller just ordered. Really looking forward to seeing how this performs compared to my old HDi electronic boost controller. :D
Just had my V2 controller and Electronic Dual Stage Upgrade Kit (missile switch) installed today. For those of you running one, is the missile switch supposed to light up blue when flicked to high boost? It did seem to light up for a few seconds briefly then went dark. I'm not 100% sure as it's not mentioned in the instruction manual at all.
Hey guys,
Just asked this question in another thread but figured this would be a more appropriate place for it, plus might help out people in future who want to know the same thing.
Does anyone know what the quality of TurboTech's boost gauges are like?
I recently ordered a boost controller from TurboTech (after reading how awesome they were) and it came with a mechanical boost gauge.
Haven't hooked it up yet tho, wanted to know if it's even worth installing first.
Now I assume that they are not their own TurboTech branded boost gauges, that they merely on-sell another brands product packaged in with their own.
I also assume that with all the raving reviews of TurboTech's controllers they wouldn't go jeopardising their great reputation by supplying sub-par accessories; but hey, I might be wrong...
Any thoughts/opinions?
I would assume the gauge is accurate "enough" for what you're doing... I've used yumcha vs. jap gauges before and didn't see any real difference between the readings.
Being a mechanical gauge too, it's more simplier to build
Yeah fair point, reason I ask though is because I think (hope) my stock gauge is reading incorrectly. Either that or I'm overboosting.
I did the ol' solder trick to the boost sender unit and it fixed it cutting out randomly, but now that it works all the time the gauge is maxing out when boosting hard.If it does happen to be showing a proper boost pressure, this means its pumping around 14 psi!...
So I want to install the TurboTech to keep it under control but don't want a gauge telling me I'm running a safe 9psi but really I'm on 15 psi and go bang! :down:
Edited by Brad54
on a stock ECU, your motor won't go bang :)
The stock ECU detects knock and drops timing, hence the knock sensor. The only thing that would go bang is your nylon turbo made with fairy floss lol
  • 4 weeks later...
Need to give big props to Turbotech for customer service.
I have had a Turbotech MBC for a good while now and recently I lost the bolt and spring from the controller. Sent Turbotech an email on Ebay to see if I could buy the bits seperately and they straight away just offered to send them to me for free not even charging for postage. Very impressed by them
lol how did you manage to lose the bolt and spring? Was it installed in your car when you realised? :/
I had threaded it out real far to make sure it didn't make any more boost than actuator pressure on new turbo. Unfortunately didn't realise it was right on the edge of the thread. I noticed I had lost it the day before tuning the car so unfortunately was only able to tune on actuator pressure
Well, lets just say that this is one awesome bit of kit! Got it in the mail today, and went for a drive, pulled up to adjust it up a bit more, set it to 18psi and it just spools straight up to max boost and friggen sits there. Drops off 1psi at redline but that's it.
I'm am very very impressed. Throttle response is off tap. Cheers guys
  • 4 months later...
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
