As far as im aware, injectors are a must as it helps the fuel flow better, a few people have done it without them, but then realised once starting to come on boost they run out of go and they end up swapping to the rb25det injectors, there is a few threads on the board about it, 666DAN did it go to his thread and see what he has to say about it.. they're not to expencive anyway
Hope this helped.
Dayne
u need ecu, or get urs remapped, injectors, fuel pump, its better to buy a half cut as it has everything, but if you dont want to do that, you can get a rb25det block and fit your NA head on, or buy the two seperately, either way you will need bigger injectors. It is better to have proper DET parts, as the compression is lower and you will have the oil squirters in the block.
Another way that you can do it is turbo you NA motor, it is possible, but the max boost you can run is 6psi and the motor is very torque as boost comes in at 2500rpm.
If you have any other questions let me know, i am able to tell you the parts you may need depending on which way you want to go.
cheers
I have all ready brought a heap of parts so i wont be buying an 1/2 cut.
I have:
*Exhast Manifold + Turbo (no lines) + Dump + Frontpipe
*Stock intercooler with piping (:thumbsup:)
..a few picutes might help me with the assembly :)
*GTST ECU
So do i just need injectors/ turbo oil and water line now?
Ive been suggest - replacing the head gasket with a thicker one to lower compression... reckon its a good idea?
brand name ones are available from japan but there super expensive, ive got a number for a place in melbourne that does the very cheap ill try track it down for you.
Sweet thanks NA_R33... i reckon! an 1.6mm HKS $632, 2mm HKS $690.. Looks like i will be sticking to high compression / low boost :P
Keep the high compression!!!!111!11one!
VW are running some very respectable boost in the new GTi...with 10.8:1 compression...like me you'd have 10:1
Now I've got the front mount on it feels like I could easily throw a few more psi into the engine with no issues.
High compression is your friend ;)
also you do realize you will need someone to bore holes in your block/sump etc etc for the oil/water lines to/from the turbo....
yeah i know. ... :rofl: and its gonna cost $$$!! to do so.
Any idea what the stock RB25DE injectors CC value, there smaller but by how much??
"RB25 uses side feed high impedance injectors 370cc"
"N/A engines I have not included these but are generally smaller"
http://www.meggala.com/injectors.htm
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
