As far as im aware, injectors are a must as it helps the fuel flow better, a few people have done it without them, but then realised once starting to come on boost they run out of go and they end up swapping to the rb25det injectors, there is a few threads on the board about it, 666DAN did it go to his thread and see what he has to say about it.. they're not to expencive anyway
Hope this helped.
Dayne
u need ecu, or get urs remapped, injectors, fuel pump, its better to buy a half cut as it has everything, but if you dont want to do that, you can get a rb25det block and fit your NA head on, or buy the two seperately, either way you will need bigger injectors. It is better to have proper DET parts, as the compression is lower and you will have the oil squirters in the block.
Another way that you can do it is turbo you NA motor, it is possible, but the max boost you can run is 6psi and the motor is very torque as boost comes in at 2500rpm.
If you have any other questions let me know, i am able to tell you the parts you may need depending on which way you want to go.
cheers
I have all ready brought a heap of parts so i wont be buying an 1/2 cut.
I have:
*Exhast Manifold + Turbo (no lines) + Dump + Frontpipe
*Stock intercooler with piping (:thumbsup:)
..a few picutes might help me with the assembly :)
*GTST ECU
So do i just need injectors/ turbo oil and water line now?
Ive been suggest - replacing the head gasket with a thicker one to lower compression... reckon its a good idea?
brand name ones are available from japan but there super expensive, ive got a number for a place in melbourne that does the very cheap ill try track it down for you.
Sweet thanks NA_R33... i reckon! an 1.6mm HKS $632, 2mm HKS $690.. Looks like i will be sticking to high compression / low boost :P
Keep the high compression!!!!111!11one!
VW are running some very respectable boost in the new GTi...with 10.8:1 compression...like me you'd have 10:1
Now I've got the front mount on it feels like I could easily throw a few more psi into the engine with no issues.
High compression is your friend ;)
also you do realize you will need someone to bore holes in your block/sump etc etc for the oil/water lines to/from the turbo....
yeah i know. ... :rofl: and its gonna cost $$$!! to do so.
Any idea what the stock RB25DE injectors CC value, there smaller but by how much??
"RB25 uses side feed high impedance injectors 370cc"
"N/A engines I have not included these but are generally smaller"
http://www.meggala.com/injectors.htm
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
