Heya Guys & Girls,
I picked up an old gazelle for a drift car project hopefully I can be drifting with Oshh!, and looking to replace the engine and gearbox to manual.
Does anyone know what engines can fit into the gazelle without too much hassel?
Suggestions are
1. SR20DET Red or Black Top approx price?
2. CA18DET approx price?
3. RB20DET approx price?
Aftermarket ecu will be used, so I guess wiring would be easier.
Do the manual gearboxes fit?
What about the drivetrain? Will this need to be modified?
I guess the brakes will need to be upgraded, will S13,S14 brakes fit?
Will S13,S14 suspension fit aswell?
The SR20 will probably be the best engine for power and weight, where can I source one in Adelaide?
And who would you recommend to do the work?
Cheers Dudes.
https://www.sau.com.au/forums/topic/73636-s12-gazelle-project/
A guy i know has one as a project car, and i know from talking to him sr20 is the way to go. Rb20 may fit, but it requires a bit of custom work to be done.
That will be a big thing you will find when you want to do anything to the car too....hes always telling me there is NOTHING that is a bolt in upgrade. Everything you want to do requires welding/cutting and making it yourself. If you cant do any of that...id sell it :P
Or try the gazelle forums :D
Hi,
Here is an S12 Gazelle/Silvia Forum: http://www.club-s12.org/board/. There is alot of Australians on here aswell as alot of US, Canadian and UK owners. Obviously the best base to start with would to have a five speed model and the IRS. As stated above, not very much is a straight bolt on. SR20 and CA18 are the best engines to drop in. I don't think you would have enough room for an RB20. S13 brakes and front suspention can be used along with some various parts from R31 Skylines. It is alot of work and it is an absolutly huge job to convert a live rear axle model to IRS and then to try and find an LSD (Best bet would be from a Z31). I was very seriouly considering doing this myself, but by the time you have it complete you could have a pretty well equiped SR20DET S13/180SX. I've decided to go for an AE86 now.
Chris.
they come with stock CA20 or something like that?
i'd put a SR20DET in it anyday. You need to change a couple of things like engine mounts and driveshaft i think. i was gonna buy a gazelle off my mate. he has all the parts including the SR20 but it needs to be put all back together.
1. SR20DET Red or Black Top approx price - 3500?
RB20DET - 2000?
the price u paid for the engine conversion + the gazelle
u can buy a S13 ca18det easily
which already have better brakes +LSD + heaps better chassis
When I replaced my RB20DET (since i bought the car knowingly with a dead engine) it cost $800, but that was minus turbo, loom, and ECU. But with coil packs and all sensors. But i had my helicoper mechanic mate do most the work swapping it over for Bundy. :)
If you want to do the project RELATIVELY cheap (no project is truly cheap but that's not why you do it) then I'd go the CA18DET, if they did in fact come with CA20's then you might have some luck with an easier fitting. If you're genuinely interested in doing a PROJECT, have some tools, and are willing to spend the time on it then go nuts.
But if you don't then you'll just be paying for someone else's junk to live at your house.
In that case I'd go with what everyone else says, and buy a S13 CA18DET, maybe one with some battle damage i.e. dead engine / stolen recovered / stacked in the arse (but good chassis), and do the bare minimum to get it running. Then strip it bare and cut sick! :)
Another alternative to bolt a dodgy turbo setup to whatever's in the S12 and run it til it dies. :(
ash, he's already got the car in his possession. I have a family friend that can do engine swaps for wuite cheap. He swapped my old mans corolla engine with another same spec engine for ~$300 or so if i remember correctly and is about to change my brothers clutch for $150. Now that is cheap - cheap advertising i know. MSN me Will if you want his details.
Will you might like to check this out: http://www.body-works.co.nz/profiles/ben.html
Seems the S12 RSX came factory fitted with an FJ20ET, perhaps engine's your best bet, and the person on that website is "Ben D" on these forums. Maybe send him a PM?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
