  • 5 months later...
Hi all
Recently have a problem with the car
When the car is idle, it would sometimes shudder/shake for about 1/2 second
This can occur randomly at idle and makes no sounds
Any suggestions at what it could be ?
Thanks
Eric
Got the same problem with my 34 GTT. It only seem to show when car is warmed up. When the oil temperture pass 90 degree and sitting idle the random shake and you can hear spluttering sound from the exhaust.
https://www.sau.com.au/forums/topic/73847-shudder-at-idle/#findComment-1649392
have had this shutter too for about 2.5years
only appears when the engine is warm, and is worse when the engine is hot
...but doesn't seem to be so bad when its a cold day
tried to change:
- afm
- spark plugs
- all coils
- ignitor
- fuel filter
- tried fiddling with wires to see if its an electrical problem - no luck
- had injectors cleaned about a year and a half ago
also tried cleaning IAC, fiddling with throttle switch, and cleaning the intake manifold with some carby cleaner all with no luck
if you find what it is, then i will have sex with a monkey
Waz.
https://www.sau.com.au/forums/topic/73847-shudder-at-idle/#findComment-1653257
tried to change:
- spark plugs
- all coils
Waz.
hmm. bugger. so changing the coil didn't fix the problem. I was seriously thinking of picking up a 6 pack splitfire coil n replace them all and hoping for problem solved. But I guess I will have to look else where.
Anyone else got the same problem and had it sort it out?
https://www.sau.com.au/forums/topic/73847-shudder-at-idle/#findComment-1662449
Mine has started doing it in the last week or two... Just a quick shudder and a gurgle from the stock exhaust system. Only when warm.
Interesting! I thought I was due for new spark plugs, cause it sounds like an occasional miss.
Do 34's have the ignitor in the ECU or engine bay?
https://www.sau.com.au/forums/topic/73847-shudder-at-idle/#findComment-1666968
Hmm.. and it is the same on my series 2 R33.. Wondering if it is getting too hot where it is and not igniting properly sometimes? Anyone with a series 1 R33 experiencing the idle shudder?
Also, Ed... does that free ipod thing actually work? I've seen the same scheme for car head units. =-]
https://www.sau.com.au/forums/topic/73847-shudder-at-idle/#findComment-1669617
I have an R33 S1 and it's also affecting me. It only used to happen a poofteenth before I got my atmo BOV and now it does it pretty hardcore. Unless I leave it for 4 hours between drives. If I warm up the car for 5 mins in the morning I'm fine. It's when I stop and start the car (like doing grocery shopping or something) that it happens most
has anyone used the the eletronic idle stabiliser?
Clicky
Does it work?
Someone mentioned that another result of shutter is also loss fuel economy... Will this also fix that ? I
https://www.sau.com.au/forums/topic/73847-shudder-at-idle/#findComment-1670156
I was going to have a guess and say; since my O2 sensor doesn't appear to be working properly, and the ECU is running richer at idle/low revs, that possibly it is backfiring on too much fuel?
I hope this is not just an uneducated guess, and i'll soon see when my NGK O2 sensor arrives.
Incidentally, i'm also running an aftermarket BOV. How's your fuel economy, Kennedy?
https://www.sau.com.au/forums/topic/73847-shudder-at-idle/#findComment-1670302
Well my fuel gauge doesn't work so I can't be sure. (Gotta fix that). I fill up every 200KM anyway coz I believe cars in general run more efficiently on a full tank. By my rough calculations...since the BOV intall by I can only get about 400KM rather than 450KM to a tank. It is a 65L tank isn't it?
https://www.sau.com.au/forums/topic/73847-shudder-at-idle/#findComment-1670436
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
