Want to go motor racing at a reasonable price without knocking your good car around???
Imported as a RALLY car. Eligible for "conditional or special" reg in local state. CAN NEVER FULL ROAD REG.....so please don't ask.
1991 R32 GTS-t, man, black. 166,000 kms - body in V good condition with no signs of rust or previous damage. No sunroof.
Engine is strong - no smoke on startup or under load. Transmission and drive train excellent.
* 17 x 7 & 8" sparco style wheels
* Apexi blue adj shocks (not the rock hard jap type) "C" ring type
* 3" exhaust
* Blitz boost gauge
* Racaro driver seat
All gauges, elect windows, locking,lights and other ancillaries work fine. A/C gassed and working.
Drives great. a base car to build on for circuit racing, club car or tarmac rallies.
$7,500.00
I have 2 other R32's. One I race in Targa (732#) and one for circuit. This car was ordered for someone else who couldn't come up with the money and now surplus to needs. Freight back to Melb will be deducted from price on purchase.
BUT PLEASE NO TIME WASTERS. Check with local authorities re rally reg before you inquire further.
email to [email protected]
or 0417 518 660 KERRY
https://www.sau.com.au/forums/topic/73849-r32-gtst-7500-racerally-only/
In most states u need a CAMS C3 or National rally licence to warrant the state authorities issue conditional reg to drive car on road to go to and from events and places of repair. Every state is different.....please enquire at home state.
NOTE: a vehicle imported as a "rally" car is viewed much more favourably for conditional reg than a car imported as a "race" car. And yes there is a difference as I have imported cars as both plus as the old 15 year rule.
  • 5 weeks later...
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
