theres hope for us all then??? at 1200kgs its 50kgs heavier than my car.... :wassup:
2400lb is around 1090kg
(actually 1088.6 kilo)
so it is really lighter than your car (by about 60kg)
:Bang: :kick:
Hmmm I like the stock looking exhaust manifold...
Stock bottom end I have HIGH doubts...especially the boost level through that turbo would see Mr Rings packing up and going home...not to mention Mr Piston melting like the wicked witch of the west...
Trick cooler though, not cheap so the budget would not be small...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
