g'day guys,
i have a little concern about my R33. whenever my turbo comes on boost, it squeals to high heaven. nobody seems to know quite what it is. i've heard some say that its a boost leak or something from the turbo seals, but the car hasn't lost any power. am installing a boost gauge shortly, so i'll see where its boosting. got me stumped. its gradually been getting worse over the past few weeks. i dont drive my car particularly hard, but i kinda have a feeling its time for a new turbo. any ideas would be great.
cheers.
https://www.sau.com.au/forums/topic/74093-noise-bad/
ok, so installed to boost gauge on the weekend to see if its leaking, and its not. its running at spot on 7psi. doesnt roll back, it just sits a dead on 7psi. so, i took off the bov to check it all out. the gasket is a thin metal one, so im thinking of changing that. but its not leaking any boost, so this is leading me to believe that it may be an exhaust bolt or something else. am yet to check the turbo, but will try to do it soon. work is flat out atm. hhhmmmmmmm.....dont know what else to do.
https://www.sau.com.au/forums/topic/74093-noise-bad/#findComment-1369453
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
