24 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 122
whats happnin people??
vote for a late kruise (my mate wit the blue 4door wont finish work till 4pm and we live in the hills so at least 6pm or later), also less traffic later in the day.
pm's the location and cruise route that is going to be taken. Im sorry if its a bit late as i went yesterday afternoon to see how the roads were and didnt get back early enough to send them. All can say is its going to be alot of fun. see you guys/girls tomorrow.
duc
ps im in the white 33
Sorry guys :D Not going to be able to make it, something else has come up - as it always @!#ing does!!! :P The route looks excellent. Hope you all have a good one.
I hope we are able to cruise or have events in which we can get together more often. I meet some new friendly faces and caught up with some old ones. I noticed that you took a left turn sam at the round-a-bout, i assume you were heading to murray?
Anyways, here are the shots that i manage to get.
My favourite pic
Twas very enjoyable thanks all for the great arfternoon. Further to the discussions shall we try to organise drags/drift or track day all together. We could check out the next few organised events and take a few skylines out?
I got to meet some new friendly faces and catch up with old one's. It would be great if we have more of these cruise or events in which we can gather and talk bout cars and what not - keep the sau section active.
btw i noticed that you took a left turn at the round-a-bout sam, im assuming you were heading to murray - should have asked if you wanted to have dinner with us.
anyways, here are the shoots that my gf and i managed to get.
started the cruise by making a wrong turn and here i am asking where some cars were :Oops:
my favourite pic
For sure, was good to see some new faces & cars. Im looking forward to the next cruise! Yeah, i had to go back to murray bridge, my mum called and reminded me that it was my grandpas 85th, and wanted to know if i would be there. Nice pics mate, im in the process of uploading mine, shouldnt be too long now.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
