  • Replies 43
Love you lots Jayce :@)
It'll be in the paper in 3 days also
Don't thank me yet;it's up to the fella to contact you if he likes what he sees...although;what's NOT to like?!?
Thanks very much Jayce and Sean.
4PKNUP: I'll send you a PM now with my number, you can come and pick them up anytime over the weekend, i'll be at work during the day saturday and at my gf's place till sunday evening but you can come around anytime during the weekend and my folks will take care of it.
and yes $170 is fine champ :@)
  • 3 weeks later...
lol your all super!
Its quite likely that the nismo front bar will now be exchanged for a trust one an resprayed. I am also having a new black leather handbrake boot put in and the couple of red bits still remaining in the interior will be raplaced by black items so the whole interior will now flow between black and creme (read:HOT!) If the car is not purchased by someone in the next 2 weeks it will be coming off the market, any imperfections will be fixed and i will be selling it in immaculate condition (going for a different kind of buyer) instead of the fu**wits with no money that want to testdrive my car with no intention of buying it (and yes i am bitter about it lol)
It will be going back at an increased price to suit its "immaculate" condition.
so if anyone wants it how it is now for the stupiudly low price its at, then i suggest you get round to my place and put down a deposit within the next fortnight!
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
