G'day.
Hicks
 Share
Dan_the_man will prolly plan a SAUWA next month some time (its only a week away!!)
We're having SAUWA drinks at the Brisbane Hotel on friday after work - come down! Thread is in the events section.
Heya Hicks, did i see u at heat about 3-4 weeks back? same as adrian? i could have sworn it was u then u dissappeared.
Nice ride, gotta love teh s15s, except when u have to go over speed bumps eh.
Hey kym, that power figure has jumped up a bit. What did you do? What turbo?
_Had_ a HKS 2535 on there for a little bit - Now it's off and I'm back to stock - gonna sell it soon and go for that dream S15 i've always wanted :(
ps you suck getting my car idea first :D
 Share
    • All the above effort, time, swapping out parts in the dark (i.e. no O2 data). You're literally running in the dark.
    • Looks like both of my cars have pressure switch issues. The R32 GTR has 18 flashes on the ATTESSA controller which is "ETS pressure switch circuit". The 4WD light is intermittent, and often just restarting the car clears it. There is an $300 replacement option https://www.ebay.com.au/itm/285675135148?itmmeta=01HXN3YKRGKQ08GRZ5KFKKZWJT&hash=item428390a0ac:g:6CcAAOSwWxBltMEG so if it becomes a permanent issue and I can confirm that the switch is the issue, i have a solution. The NM35 is reporting C1208, and disconnecting the switch causes the 4WD light to go away. Translating from the Japanese shop manual "when the pressure is reduced to 2.6MPa (377 psi) or less: conduction occurs when the pressure increases to 3.8MPa (550 psi) or less: conduction is present. Reference: • Immediately after the E-TS actuator motor stops, the pressure inside the accumulator is high and there is no continuity." Not sure how good the translation is but from what i can deduce this means the switch is normally closed (NC) and as the pressure builds from 0 to 550 psi the switch stays closed, then opens and 550 psi. As the pressure drops from 550 psi to 377 psi the switch stays open then closes again at 377 psi. Is that how these things work? These pressures are a lot higher than the R32 ("control pressure 0-228 psi") but i'm hoping i can find a generic switch (like they've done for the R32) to use as a replacement. Maybe something like https://www.ebay.com.au/itm/355586397452?epid=1676016964&itmmeta=01HXN534AF22ACTG6TGDDQGEQ7&hash=item52ca99d50c:g:mAEAAOSw8ilmBcMh&itmprp=enc%3AAQAJAAAA8LtWdNlWHgyJ%2F3cbw25S2A1lde3qBi3fJii4T3lQavCz4kpqiD42SmBa4FocMvXCjcxiowHjb8vZ8%2BWxc53BkHv781tkStSnCDaenfGKC3bIp0keK20dfsn9LoPa3TfqaEmAydqqyKobgTdXsGGzsl%2BRjOVGuD8OIpOv%2B0wMl7aUtHg0iJtojbtzA%2BRS8Xfm8Ufjuvz4niwrqglAXFUbkL6J%2FGuHPeeECZhLBBN3iNM1Swl94Fv5zE95YK%2B5O6dxDN1ySNOjdMxkA8yaprbuwRHFQv1nlGh%2FWjekj6EUFR2%2FO4HTsoKtSAkY0Mj1w1uf1w%3D%3D|tkp%3ABk9SR6zFjKXtYw but with a lower close pressure, and thread adapter if required. Am i dreaming?
    • That is a dead f**king short of B+ to ground. Scary.
    • 10-15 years ago, the answer would always be buy a good import motor and so many machine shops make.a hash of an engine rebuild, or they think they are some sort of RB magicians and want 40k.      Now as others have stated, you are buying a VERY old used motor. So rebuild is the correct answer.  Just finding a machine shop that will both do a good job and charge you a regular price is now your challenge.
