Has enyone used a straight through replacement pipe for their cat converter?
I am looking at getting one made up for track days and drags, but not sure whether to keep the Lambda sensor just behind the cat.
My thoughts are that, removing it will cause the car to run rich as it is missing a sensor and may try to run in a " safe " mode. Or if I leave it, it will cause the sensor to read worse pollution levels than if the cat was present and it may run lean.
I am currently runing a full 3" systems, PFC, FMIC, 550cc injectorsand T3/T4 turbo.
If anyone has used one let me know if you have had any ill effects, and any noticable performance gains/losses.
https://www.sau.com.au/forums/topic/74897-cat-replacement-pipe/
the sensor in the cat is a cat temp sensor. the O2 sensor is in your dump pipe, well before the cat. no need to hook up the temp sensor, it just activates the warning light on the dash which is there to prevent you parking on long grass when your cat/front pipes are glowing red thus igniting the grass and burning your car to bits.
Thanks for your help guys,
I need to get a custom one because the car has the cat welded to the exhaust system, and I will need to get flange plates installed to bolt it on and off.
Any idea on the performance gains of doing this?
I know it depends on how effiecient your current cat is, but what has been your experiences?
i always thought it was to tell you when your cat was overheating, so you can back off to avoid damage?
steve
no, it's to warn you of all that heat in your exhaust so you wont park in long grass and blow your car up or start a bush fire.
Best I have seen was a 40rwkw gain. Least I have seen was a zero rwkw gain, that was with a Magic 4" cat. Pick a number:cheers:
The magic cat manufacturers can supply 3 inch reducers if you want or you can get your local exhaust shop/yourself to do it.
They retail for $500.00 or $350 trade.
Search "magic cat" and look for sydneykids comparison with a magic cat, "highflow" cat and straight pipe. Interesting stuff.
I was quoted $100 to get flanges put either side of my cat so I can swap it to a straight through one for track days as someone above mentioned. He said the flanges would be about $60 and whatever labour, they are a cheap workshop though but that should give you an idea on price.
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
