Hey all, I joined the GTR club today with a 1993 R32 GTR, Gunmetal Grey......Bought my first car over 2.0L and first car with 2 turbo's let alone 1 turbo :headspin:, these things fracking boot like nothin' else, 80 in second, WOW! :D:P
massive upgrade from my 1.8L non-turbo TX3 :kick: , I am lovin' this thing :wassup:
Will post pics tomorrow, too dark to take any at the mo...
https://www.sau.com.au/forums/topic/75414-enter-godzilla/
  • Replies 57
80 in second, WOW!
Really... They dont do 100km/h in 2nd? Rev it more man!?
I know the r33 gtst's do 100km/h @ 7000rpm.
Dads Euro accord is not bad, 120km/h @ 7000rpm
I wish 1st gear was more like 75km/h rather than 50km/h in the r33. I find 1st isnt very good for booting coz its just wheel spin, although if I was 4wd like ur GTR 'u basted lol' I spose 50km/h is fine.
https://www.sau.com.au/forums/topic/75414-enter-godzilla/#findComment-1385665
well that was just a little test....and yes about 15mins ago I took it for a spin with brothers mate and got 100k's in 2nd @ ~7000 ;)
I'm f***kin' lovin' it :wassup:
https://www.sau.com.au/forums/topic/75414-enter-godzilla/#findComment-1385680
Mines 'totally standard' bar a cat back 3" exhaust and pods and i'm pleasantly suprized at how well it goes in a straight line, should hold its own against most factory cars.
Certainly a big jump from your previous Lazer ;)
But dont get to excited as there not that fast, and theres still plenty of cars out there that will smoke you (and Me!) :)
And IMHO its not a good look getting smoked in a GTR as generally people expect them to be quick and win...be selective who you race :);)
https://www.sau.com.au/forums/topic/75414-enter-godzilla/#findComment-1387472
Aim to achieve about 450rwhp which can be done with a turbo/injectors/afm/powerFC/exhaust/cams combination.
It is reliable on a good, stock internalled, engine and won't destroy the gearbox/clutch/drivetrain.
Then there wont be too many cars on the road that will smoke it :) :)
Cheers
Ken
https://www.sau.com.au/forums/topic/75414-enter-godzilla/#findComment-1387481
yeah, I'm guessing some R8 commodores and TE/TS50 Falcons would beat it
but I am not that confident in changing gear fast yet :)....feels a bit bumpy in the change too
I rekon the fun thing is letting little excels, lancers and lasers beat you :)...and you in the GTR easing up to the speed limit
https://www.sau.com.au/forums/topic/75414-enter-godzilla/#findComment-1387485
no factory standard R8 or falcon should come close, especially from standing start!
https://www.sau.com.au/forums/topic/75414-enter-godzilla/#findComment-1387501
remove the boost restrictor and retune the stock ecu and not much will come close :crazy:
https://www.sau.com.au/forums/topic/75414-enter-godzilla/#findComment-1387506
heres a little list of the mods/repairs:
16/09/2003 at ~82,000kms:
Oil Filter
Coolant
Fuel Filter
Penrite Pro Oil
21/11/2003 at ~84,000:
Water Pump
Top Tank + Coolant
25/06/04 at ~89,000:
Manifolds: Exhaust, Both Turbo's, Inlet Tube, Tube Assy, Water Wetter, Oil Filter, AGIP Oil
28/12/2004 at ~93,000:
FULL ENGINE REBUILD - way too many parts to list, all belts, filters, oils, seals, gaskets and 2 new R34 turbo's
cost $5700 (with free labour, last owners dad's workshop did the work)
over $7,500 of receipts
also have boost guage, turbo timer, pod filters
currently sits at 103,000kms
https://www.sau.com.au/forums/topic/75414-enter-godzilla/#findComment-1387510
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
