Hi,
I have a dilemma, if this is in the wrong section, mods please move it.
My diff in my car makes clunking noises, but only when turning and moving very slowly, i.e. car park, but only when i accelerate, is this a mech LSD or locked diff?
David
Id say mech diff man, prob 2way especially if you have a cefiro. If its really bad try chaning the oil, helped mine a bit.
A locker would be constantly locked, so your tyres would just chirp going round corners slow, which with effort you should be able to get yours to do.
My diff makes a similiar noise to urs as well...its been like that since i bought the car, changed the diff oil once made no difference. So you guys say it is a Mechanical Diff? Whats the diff in the R33 s1 from the factory? not Mech i take it.
How do you know its 1.5 or 2 way diff?
2-way mech diffs will chirp on corners unless clutch is in. (as soon as u put foot on clutch, it will un-lock)
fully locked diffs ie spooled/welded will chirp always regardless. Trust me, you'll know if it's a fully locked....
factory diff is a viscous lsd, which will only lock under decent load.. and depending on how worn it is, only locks some of the time...
for a good article on diff's goto http://www.garage-13.com/difftech.html
if it's a 1.5 way, it will only half-lock on deceleration. hard to tell unless you drift it. only other way is to take out the centre and look at the shape of the plates.
That's what happens with my car. I thought it was a mech-2way because when I clutch it it rolls better in tight corners. But when I had my car up on lift I spun one of the rear wheels & the other wheel spun in the same direction making me realise it's locked.
ok so when i imported my car it came with a locked diff (and is still in there) i only notice it when im cornering at all and clutching does not affect it. Not 100% sure what type it is but will find out asap (as i want to know) what are the advantages and disadvantages of a locked diff for daily driving???
I questioned keeping my locked diff hey, was considering pissing it off but end up thinking the advantages are better than the disadvantages.
Advantages:
1. Always 50/50 power to the rear wheels, great for straight line dragging.
2. IF you like drift it's awesome for drift, much easier to get the tail out & keep it out.
Disadvantages:
1. Dangerous in wet, have to be VERY gentle on throttle when turning. I was changing lanes around a light corner in 2nd in the wet gently accelerating & the whole tail bloody kicked out in a flash, lucky the room I corrected in had no cars next to me...
2. Bad cornering in general, tail still wants to slip out if you're pushing it.
3. Tight turning can be annoying but its not that bad, the bad cornering disadvantage is the worst not being able to really push the car as hard as it could be cornering.
Advantages:
Disadvantages:
yeah im still undecided as its a daily driver and get some very funny looks from people when slow driving in the middle of town and i dont really like the idea of my tyres skipping all the time when turning slow corners wearing them out even faster than normal!!!
A good 1-way LSD not too tight but not too loose, just right 'like the cereal :bonk:' would probably be your best bet. You'll get best possible cornering & 50/50 power when enough torque is being thrown at it. I’d love one of these diffs but I don’t mind a bit of drift every now and again 'as my signature gif may suggest' so I’ll just keep my locker.
Hi All,
Seeing as we are talking about diffs i was hoping to get some thoughts on a situation i have with the diff in my 32 gtr. I only picked the car up recently and the diff seems to be fully locked no matter what the conditions. Real annoying. Ive changed the oil and it made no difference. So my thoughts are that its either stuffed or been intentionally locked.
I dont know a whole lot about diffs, but i would have thought if it was "stuffed" that it would simply loose its LSD effect rather than have it permanently lock up, so i doubt this is the problem. However i also cant understand why someone would want to put a fully locked diff into a STOCK gtr.
Any thoughts/feedback would be much appreciated.
Hi All,
hey,
sounds interesting.. does it skip around corners? and your right LSD's usually from my experience stop working as they wear.. like one of mine has.. but it could depend on what sort of lsd unit it is.. ill check with some sources i have and post another reply tomorrow... if you want to i can look at it depending on what i come up with.. talk soon..
Hi All,
hi again..
i found out some info today.. unless yours is minispool in which case there isnt much you can do about it (besides buy an lsd unit).. heres what i can tell you
aparently the gtr's came out with five different LSD units.. viscous, mechanical and clutches are probably the most common.. clutch lsd centres if they fail they act as an open wheeler only spinning one wheel... viscous lsd centres can go either way, wither lock or open depends on what fails (i would have thought more often open wheeler) and finally mechanical ( which i think yours possibly would be) which will lock when stuffed usually.. if your experiencing under steer and skipping around corners (possibly not all the time) then id say this is what you have and its stuffed..
whatever you do dont just rip the diff out and chuck it.. people will pay top dollar for mechanical lsd units (stuffed or not) because they are hard to find.. you'd want to rebuild yours if possible.. hope it helps... let me know how you go
john
Hi,
David
hey mechanical lsd units that are stuffed clunk around corners when moving slow
hi again..
john
Hey thanks for the info. It should be taken out this coming week so ill let you know what the outcome is. Im not sure what im gonna do to fix the problem as yet... But ill let you know what the problem is and may be bounce some ideas off ya.
Thanks.
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
    • Oh, and as for everyone with their fuel economy changes, I switch between E10 and 98 in the company car. Even do when I had personal cars that could run on E10. You know what changed my fuel economy in any noticeable way? How I drove, and where I drove. Otherwise, say on full tanks of just back and forth from work only (So same trips, same sort of traffic), couldn't notice a difference that I can correlate to the type of fuel in use. In the current vehicle, that's over 42L of USABLE fuel. While 98 is all "more energy dense", it also has higher knock resistance as it takes more energy to get it to ignite too. The longer hydrocarbons, typically more tightly bound. So running the same ignition map, can also produce less power, if there isn't enough time to get it all burnt through properly, as yep, the flame propagation speed is different from lower octane fuel to higher (Higher has a lower flame propagation, due to the more tightly bound and harder to self ignite funs. This is also typically where, a vehicle that is designed purely to run on 91 (Whether it be E10 or normal 91) usually sees absolutely no real world difference in fuel economy for the normal man, woman, or dog.
    • We've got some servos around me that have 91 with E10, 91 (no E10), 95, and 98. At those stations the change from 91 E10 to 91, is typically around 8c/L.   But lets not get started on the price of fuel in Oz. It's ridiculous. All the service stations around me, bar one, the price of fuel has been over the $2 mark per litre for the cheapest, 98 being around $2.45. That one service station is a CostCo, fuel from it comes from the same refineries, and makes no pitstops, it runs great, including the 98. In fact, I've had no issues on CostCo fuel, but plenty of issues at other stations!. The CostCo fuel, was $1.65 roughly this week for 94 with E10. $1.88 for 98. Servos directly across from it, $2.10 for 91 E10, and $2.48 for 98. The part I had to laugh at? If I drive multiple HOURS away from Brisbane, say out near Nanango, or Kingaroy, or even out to Goondiwindi, the price of their fuel, is the same as what it is at the CostCo... Oh, and that BP servo at Goondiwindi is HUGE and goes through epic turnover of fuel, so it's not sitting there for weeks going to shit. And what blows me away, my mate is one of the people who drives the Fuel Tanker all around QLD, delivering to all those places. At the same company his previous role was doing the "local haul" deliveries... Same truck, same driver, same pickup point it all comes from. So you tell me, how the hell it is 60c/L CHEAPER for fuel, when nearly all else is equal, except they require a B-Double to drive half a day out of Brisbane, and half a day back, every second day, compared to the delivery that can be under 30 minutes drive from the fuel pickup point... Not to mention, go five blocks down the road, and Ampol to Ampol will vary 30c/L... And I've had this conversation with my mate... The way it's priced, is just typical, pure and utter rubbish... He also does runs from Brisbane, to all over QLD, down to Newcastle, Sydney, Nowra, Melbourne, Geelong, and even out to parts of the NT depending on the companies needs. His main stuff is all the longer distance away from home for a few days at a time, then when he's back, he loves to just pickup extra shifts wherever he can in whichever truck, hence all the weird different places.   Oh, as for getting E10 into all the fuels in Australia... It was very quickly highlighted, that we don't have enough biomass available to use to make E10 sustainably like they require, and it would dramatically cut into our, and the worlds food chain supply...   I vote we all just start running on liquid methane gas... Plenty of that just getting tapped off at tips from underground decay... (Note, this is pure just stupid commenting. I could very easily highlight the reasons its not a good idea especially on scale...)
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
