when my head was taken apart the idiot bashed the 12 inlet guides out with a punch and rooted them beyond belief. all the guides had a bit of wear but were still fine to use, the engine had done 100,000km or so i believe. if you have to replace them with new ones, there's a trick.
new from nissan they are $90 each or something stupid like that. aftermarket ones do not exist (at least, my engine parts stockist could not get them) but we measured em up and found:
OD: 10mm
Length: 38?mm can't remember exactly.
anyway turns out the CA18 uses exactly the same measurements, but the guide is physically longer. buy 12 of them for $100 or so and lathe the ends off to bring the length down. works a treat!
Get a quote from a local engine reconditioner to have the guides k-lined, which is a bronze insert used after the valve guide bore is reamed oversize. Usually cheaper than new guides, plus has better wear characteristics.
But before you do anything, have the valves measured for wear as well as the guides if there's cause for concern.
  • 2 years later...
I won't k-line these heads, they don't last. Use CA18 guides as described above. heat the head to remove them and heat the head and freeze the guides to install them. The only time i've seen guides worn is where they have had k-lines fitted, I've also seen a CA18 head where the guide has come loose. K-lines have their place, just not in these engines.
  • 6 months later...
Nothing at Rocket - waiting for a call back from one of the boys at Hi Octane. I called them to start with but they said that all they kept in stock were the Tomei Beryllium ones and there's no way known I'm spending 700-plus on valve guides.
  • 1 month later...
does anyone know if the r33 valve guides also fit the r34 NEO? And when would i start to consider replacing them for a/m? Besides the obvious being worn out, is it the power or the rpms that factor? I will be reving to 8000rpm ( rb25/30) and 700rwhp. for argument sake they were in good condition, should i still go a/m? tomei seems the way to go.
yes i know...and pretty dam cheap compared to some here in aust. But do i need them? 8000rpm and 700rwhp? My stock are fine and head has come back from engineering.....So if i decide to go a/m its the downtime waiting for delivery and the extra labour involed. Workshop said i didnt need them but just want to get others opinions
i spoke to a supplier and they said that tomei rb25 and rb26 use same guides..Can anyone confirm this? Also if r33 guides would be the same as r34? Im thinking i should replace just to be on the safe side. Would be good to hear from people who still used their standard guides and what power/rpm they achived
    • Agreed, I've never seen a 260RS specific manual. As GTSBoy said it will mostly be stagea other than the engine loom https://www.hgeconsulting.com.au/stageaservicemanual.pdf
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
