when my head was taken apart the idiot bashed the 12 inlet guides out with a punch and rooted them beyond belief. all the guides had a bit of wear but were still fine to use, the engine had done 100,000km or so i believe. if you have to replace them with new ones, there's a trick.
new from nissan they are $90 each or something stupid like that. aftermarket ones do not exist (at least, my engine parts stockist could not get them) but we measured em up and found:
OD: 10mm
Length: 38?mm can't remember exactly.
anyway turns out the CA18 uses exactly the same measurements, but the guide is physically longer. buy 12 of them for $100 or so and lathe the ends off to bring the length down. works a treat!
Get a quote from a local engine reconditioner to have the guides k-lined, which is a bronze insert used after the valve guide bore is reamed oversize. Usually cheaper than new guides, plus has better wear characteristics.
But before you do anything, have the valves measured for wear as well as the guides if there's cause for concern.
  • 2 years later...
I won't k-line these heads, they don't last. Use CA18 guides as described above. heat the head to remove them and heat the head and freeze the guides to install them. The only time i've seen guides worn is where they have had k-lines fitted, I've also seen a CA18 head where the guide has come loose. K-lines have their place, just not in these engines.
  • 6 months later...
Nothing at Rocket - waiting for a call back from one of the boys at Hi Octane. I called them to start with but they said that all they kept in stock were the Tomei Beryllium ones and there's no way known I'm spending 700-plus on valve guides.
  • 1 month later...
does anyone know if the r33 valve guides also fit the r34 NEO? And when would i start to consider replacing them for a/m? Besides the obvious being worn out, is it the power or the rpms that factor? I will be reving to 8000rpm ( rb25/30) and 700rwhp. for argument sake they were in good condition, should i still go a/m? tomei seems the way to go.
yes i know...and pretty dam cheap compared to some here in aust. But do i need them? 8000rpm and 700rwhp? My stock are fine and head has come back from engineering.....So if i decide to go a/m its the downtime waiting for delivery and the extra labour involed. Workshop said i didnt need them but just want to get others opinions
i spoke to a supplier and they said that tomei rb25 and rb26 use same guides..Can anyone confirm this? Also if r33 guides would be the same as r34? Im thinking i should replace just to be on the safe side. Would be good to hear from people who still used their standard guides and what power/rpm they achived
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
