WTF?
Are you guys serious? Was it a bloody terridactal egg or somthing?
u obviously dont know what the contents of an egg does to paint ;) not to mention the shell on impact.
IF YOUR CAR EVER GETS EGGED WASH IT OFF THOROUGHLY AS SOON AS U SEE IT.
Never let it sit there... even if u rinse it.
https://www.sau.com.au/forums/topic/75936-eggs/#findComment-1395415
yeah, unfortunetly this happned at night and i didnt see it till the next day evening. i washed it off ASAP, just on the spray. used a soaked mic-fiber to do the rest, but still theres lil scratch marks.
only if could get my hands on the bugger who did it!
https://www.sau.com.au/forums/topic/75936-eggs/#findComment-1396123
In what areas have these egg attacks occured?
I can't believe how demented people are in this day and age to have no respect for other peoples property. We drive a Japanese car.....WHATS THE BIG F*(kiNg DEAL?! Its just plain sad for people to have such a hatred for what....a car?
Anyway, I can just imagine the damage on a black Skyline....makes me cringe.
https://www.sau.com.au/forums/topic/75936-eggs/#findComment-1404223
hmmmm I say we go vigilante on the pricks.......teach them some discipline.....so that the next time they see an egg, they'll fall to the floor and start shivering like a mouse on crack that's been poked with an iron rod........repeatedly ;)
https://www.sau.com.au/forums/topic/75936-eggs/#findComment-1404231
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
