WTF?
Are you guys serious? Was it a bloody terridactal egg or somthing?
u obviously dont know what the contents of an egg does to paint ;) not to mention the shell on impact.
IF YOUR CAR EVER GETS EGGED WASH IT OFF THOROUGHLY AS SOON AS U SEE IT.
Never let it sit there... even if u rinse it.
https://www.sau.com.au/forums/topic/75936-eggs/#findComment-1395415
yeah, unfortunetly this happned at night and i didnt see it till the next day evening. i washed it off ASAP, just on the spray. used a soaked mic-fiber to do the rest, but still theres lil scratch marks.
only if could get my hands on the bugger who did it!
https://www.sau.com.au/forums/topic/75936-eggs/#findComment-1396123
In what areas have these egg attacks occured?
I can't believe how demented people are in this day and age to have no respect for other peoples property. We drive a Japanese car.....WHATS THE BIG F*(kiNg DEAL?! Its just plain sad for people to have such a hatred for what....a car?
Anyway, I can just imagine the damage on a black Skyline....makes me cringe.
https://www.sau.com.au/forums/topic/75936-eggs/#findComment-1404223
hmmmm I say we go vigilante on the pricks.......teach them some discipline.....so that the next time they see an egg, they'll fall to the floor and start shivering like a mouse on crack that's been poked with an iron rod........repeatedly ;)
https://www.sau.com.au/forums/topic/75936-eggs/#findComment-1404231
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
