Sorry i'll fix that up
My rubber is falken ze 326 series. 2x 255/40/r17, 2x 235/45/r17
Fair amount of rubber left on them, only want $300, EASY road legal, plenty tread left.
The rubber is the same around (40,45) is just worked out on the width... works out the same hieght.
Dayne
  • Replies 52
Dayne
i dont think you understand they have to be EXACTLY the same :uh-huh:
Yup,spot on Leech! Ah well,at least dayne wanted to help! I'm about 48 hours away from having to use my normal,new Pirelli's(which just aren't as good as what I'm after...). Sigh:keep on huntin'...
They dont have to be the same size, just rolling diameter... if you have wider profile a higher profile sidewall could well work... too much pain in the ass calculating though.
Jayce, if $1000 is within your budget, check out the Falken RS-V04. Theyre meant to be fairly good, and alot of jap track cars run them. If you order tomorrow before 2pm-ish from Tempe, they can be here Friday and you can probably get Ed to fit and balance them tomorrow afternoon, or on the weekend some time.
Mmmmmmm :wassup: sticky-icky-icky ooooooooooooooo-eeeeeeeeeeeeeeeeeeee
EDIT: Thats assuming Tempe have them in stock... everytime I have talked to them after a set of RT215's, they have had these in stock (and not the RT215's) and theyre a proper R compound.
I've run the SRVS04s from Tempe, and while they are not the best R tyres they are better than any road tyres. And lets face it, when they are that cheap who cares?
I paid $250 ea in 245/45/17
Stoopid question,but are these tyres DOT/road legal? I might just bite the bullet anyway...
I was about to say "sure all R tyres in Aus are road legal".
But AFAIK Tempe import these direct from Japan so they may never have been tested for compliance. Best to check with them directly.
It really saves hassle when you can drive to and from the track on your race tyres, I've done heaps for trips to Wakefield and back on various R tyres
Thanx Duncan-I reckon this is a goer...I just PM'd Abo Bob re:his tyres;we'll see what transpires,shall we? Either way,bring it on!
so is E and Her forester gonna have a fang round the track? :D
Nup;she's a little banged up after a "racing incident" at Hume Go Karts,plus20" rims that are under-tyred are too much of a risk...if she's up for it,she's welcome to have a steer of the 32...
what hapened at the karts? she flipped one of em didn't she
Nup;taken out by an erant wannabe that wouldn't hold her line-E. was just in the way at the time...
Anyway:onwards to Wakefield!
(Now that I've jinxed myself,watch as my tyres DON'T show up in time to fit 'em up...LOL)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
