Ok, Im looking at sway bars for the cefiro, as Im still not happy with the set up even with rasing the car, the corner balance, numerous oppinions and suggestions (which are all almost identical) in terms of front end set up with camber, caster etc.
Sooo, pros and cons of them. How do they work, why are they needed/not needed. Is adjustable worth the extra money, and finally, Id be using S13 ones, the cef is obviously a fair bit more heavy, and this Im guessing would be even more so on corners, braking etc due to inertia, so keeping that in mind would I need to go bigger.
BTW, the idea of the car is good for normal street driving, more spirited street driving, and then for some semis to be thrown on the car for track stuff. Basically set up for fun, not professional race car or drift car.
Thanks!
https://www.sau.com.au/forums/topic/76017-sway-bars-yes-again-i-searched/
  • Replies 43
swaybars will not affect the ride or comfort in a straight line, they dont have the same affect as shocks and springs or bushes... their proper name is anti-roll bars.
they connect the chassis to the control arms and hold it stiff through out corners, reducing body roll, keeping the car centred throughout the corner. alot of coilovers are that stiff that emphasis on swaybars is not so important. if you want to see how much of an affect swaybars have, remove them all together and go for a drive...body roll central as the car is relying on the springs to take the weight of the car + inertia of the corner.
they dont affect castor or camber, or any alignment specs.
aftermarket adj. s13 ones will be fine in the ceffy, they arent that much heavier. yes it is worth getting adjustable ones.
hope that helps
cheers
Linton
Probably the thing to recognise is that the anti-roll bars don't much affect a car's ride/handling compromise in a straight line. It's the dynamics of lateral weight transfer when changing direction (turning) that they impact on quite significantly. Adjustable bars can give you the option of quickly altering the dynamics, say if you wanted to induce specific characteristics for drift or circuit work.
For handling upgrades there seems to be two schools of thought: big bars; and high-rate springs. Anti-roll bars at least allow you to retain ride quality and power-down because the wheels can maintain closer contact with the ground imperfections rather than the chatter that can occur with rock hard springs. Adjustable bars allow you to mimic the effect of installing different size (diameter) bars by changing the leverage rate between the bar and chassis. Using them just gives you the option of making the car respond differently, quickly.
Anti-roll bars are actually a laterally mounted torsion bar (spring). Because they store and then release engergy, they impact on the RATE of lateral weight transfer and hence the rate of suspension movement, they control the rate of camber change that a given wheel experiences in that cornering moment. So yes, bars will not affect your static suspension settings - but in the dynamic environment they will. That is partly how changing their sizes brings about handling differences.
I looked on the whiteline site before, and they seem to be about $500 for a set (havent done the normal run around to find the cheapest price yet).
I was going to say is $500 worth it compaired to say 'X' something else, but I dont think there is anything else that I can do without going nuts.
Im still interested to know someone whos done some track work with out them, but say decent suspension gear, then got the sway bars on, and whats their lap time improvement been like.
Same springs, same shocks, same tyres, same camber , same caster, same engine power, 3 seconds a lap faster at Eastern Creek.:cheers:
Aftermarket sway bars are a 'good thing', but to say they dont affect ride comfort is simply not true. A heavier sway bar reduces the 'independance' of the rear suspension, and thus ride quality is definately affected.
I got a whiteline swaybar for my r33, it was like just under $200.
I've got no clue about racing/suspension etc etc, but I think it made a differance to the handling, the car was more reponsive when turning, Kinda made it feel abit heavier and smoother. It felt safer and more comfortable going round the corners faster than before basicaly.
Not a big issue that, with the suspension and the diff, its not that comfy to start with :)
ionos.... ive had heavier swaybars fitted to all my cars, havent got any for the 33 yet though. but on my honda, r31 skyline, and my 00' subaru liberty, and didnt notice any change in driving in a straight line, also made cornering much more stable and comfortable, body was all over the shop and carrying on.
what makes you say that ride quality is affected??? with swaybars, there is no downside.
They are going to be put on the back burner for a bit anyway. Spoke to another suspension shop and they seem to think most of my problem is set up (and they said new whiteline price list is coming out soon and they are going to be cheaper). But he seems to think TOO MUCH castor, and too much rear camber. So what he is saying is fix that up first, see if thats whats causeing oversteer still (which he was quite sure would be). Then go sway bars after that to see what effect they have. But he didnt want to try and bandaid the problem.
Daveo - not to hi jack but I'd like to post some observations from a drive I recently did and the things I noticed and if they're the same as you are trying to get rid of.
Basically, 2 things. One was I seemed to get a lot of 'washy' understeer from corners around 70-100kmh which resembled driving a GTiR. That is, it wasn't full understeer but enough for me not to like and feel the front wheels slipping through the corner. This was not at redline but probably about 50% rpm or less (because I didn't feel like coming off the corner heh heh so wasn't pushing it).
The second was when braking late (I didn't anticipate the corner being so long and so angled) the car really REALLY felt like going to the apex. Fair enough I realise that's just bad driving but it was the first time I really felt the weight of the ceffy. I would have thought you can counter this somewhat by suspension settings.
Are these the things you are also experiencing? Because as far as I know I don't have sway bars (or if I do they're stock).
Not hijacking at all dude, its good to see what others cars are doing.
The first bit kinda... atm I find my car really quite settled, never too scared to keep the boot in. Plus we have changed mine so it WONT kick out, it just seems if I power down, it goes straight (no where near as much as it did before we raised it 2inches) And the outsides of my tyres are still wearing more than the outside.
I find with braking tho mine is fine, I'll out brake most cars, doesnt feel heavy or anything. And I still need to get braided lines, and a brake booster stopper on. But I did get the sensation you are taking about, its more so a mental thing I think, as you reaise its getting a bit close a bit fast, so you think the car isnt slowing down. ;)
......he seems to think TOO MUCH castor......
That seems an unusual thing to say. The only real downside to heaps of castor is heavy steering, and since we all run power steering thats not an issue. How much caster are you running?
Daveo - cheers.
1- When you say straight - do you mean straight into the apex against the way the wheels are pointed? if so that's what I felt.
2- My brakes are great, r32 type M + project mu brake pads. The feeling I meant was the car had no problem stopping, but if you picture heading round the corner, just before the apex, lock it up and you'll head straight out of the apex and off the track. This is the sensation I mean.. the feeling that the car is just... very much heading out of the apex on a late brake. I know you'd get this with any car but the ceff I just felt it a helluva lot more (for what seemed to be not much late braking at all) than I expected.
What he is saying is it induces bump steer etc, and for the extra bit of stablity you get its not worth it. Remember cefiro is S13 suspension, so not as good as skylines.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
