satanic Posted September 10, 2005 Share Posted September 10, 2005 Just got my FMIC installed today... good work all round for a DIY job (will post up in thread and blog later on). The bad news is that the factory snorkel for the R34 is no longer usable since the IC piping is in the way. What next? Looks like I'll have to fabricate a new snorkel somewhere or go for the pod. I really don't feel like going for the Pod atm since it's "illegal" and it's going to cost me a fair bit to get it all right (pod, CAI, etc.). Link to comment https://www.sau.com.au/forums/topic/76024-pod-or-air-box/page/2/#findComment-1575929 Share on other sites More sharing options...
elbee111 Posted September 10, 2005 Share Posted September 10, 2005 Just got my FMIC installed today... good work all round for a DIY job (will post up in thread and blog later on). The bad news is that the factory snorkel for the R34 is no longer usable since the IC piping is in the way. What next? Looks like I'll have to fabricate a new snorkel somewhere or go for the pod. I really don't feel like going for the Pod atm since it's "illegal" and it's going to cost me a fair bit to get it all right (pod, CAI, etc.). <{POST_SNAPBACK}> I like this. A mate of mine did the plastic welding for me. This is on R33 GTSt El Bee Link to comment https://www.sau.com.au/forums/topic/76024-pod-or-air-box/page/2/#findComment-1575944 Share on other sites More sharing options...
satanic Posted September 10, 2005 Share Posted September 10, 2005 HOW DID YOU DO THAT????? Link to comment https://www.sau.com.au/forums/topic/76024-pod-or-air-box/page/2/#findComment-1575947 Share on other sites More sharing options...
elbee111 Posted September 10, 2005 Share Posted September 10, 2005 I used a grinder to cut the shape around the piping, then my mate cut a section of this thick plastic that we use in our line of work. He warmed it to get the bend and then "plastic welded" the new section to the air intake. The plastic welding consists of using a pencil type torch and melding the two plastics together. It looks pretty good. The rough sections you can see are where I had a go and fixed some small pin-holes that he left after filing it nice and smooth. El Bee Link to comment https://www.sau.com.au/forums/topic/76024-pod-or-air-box/page/2/#findComment-1575955 Share on other sites More sharing options...
satanic Posted September 10, 2005 Share Posted September 10, 2005 FARKIN that's MAD!!! Thanks El Bee.... you've now solved my problem Time to start fabricatin' Thanks for that, most helpful Link to comment https://www.sau.com.au/forums/topic/76024-pod-or-air-box/page/2/#findComment-1575962 Share on other sites More sharing options...
elbee111 Posted September 10, 2005 Share Posted September 10, 2005 FARKIN that's MAD!!! Thanks El Bee.... you've now solved my problem Time to start fabricatin'Thanks for that, most helpful <{POST_SNAPBACK}> No worries. Good luck with it. It looks like it was made that way eh? When you open the bonnet it looks quite standard. I found the piping was scarily close to the fan blades and so went with a 16 inch thermo rather than trim the blades. All the best. El Bee Link to comment https://www.sau.com.au/forums/topic/76024-pod-or-air-box/page/2/#findComment-1575969 Share on other sites More sharing options...
satanic Posted September 11, 2005 Share Posted September 11, 2005 Hey El Bee After being inspired by your photos last night, I hit my stock snorkel with the angle grinder today The results were quite good considering my first real attempt at plastic modification. I haven't had time to do the plastic welding yet, will have to fabricate some pieces, so I just used so heat proof tape for the time being. Looks kinda the same as yours, but ultimately I hope it to look just as "factory" as your creation. Cheers for the idea; tell me what you think!!! Thanks Stan Link to comment https://www.sau.com.au/forums/topic/76024-pod-or-air-box/page/2/#findComment-1576802 Share on other sites More sharing options...
SKY 34 Posted October 6, 2005 Share Posted October 6, 2005 I read in some mags that pod filters are useless....well they are there for the looks and the sound sound like the car is alive, breathing...I like that effect....I replaced my factory filter with HKS green mushroom and ...no difference in perfomance...... while more air is sucked in by the pod filter...those air are warm, unshielded from the engine bay... warm air has lesser density, lesser Oxygen for combustion...in effect mushroom = factory... I discussed adding heat shield around the filter with the mechanics...there are some carbon fibre ones available...but if you think abt it, the air is still from the engine bay only less hot and heat shield would restrict the air flow....end up with warm air and lesser volume sucked into the filter, even worse effect.... standard is the best I guess...I switch only because I want my car alive!! lol Link to comment https://www.sau.com.au/forums/topic/76024-pod-or-air-box/page/2/#findComment-1626240 Share on other sites More sharing options...
dezz Posted October 6, 2005 Share Posted October 6, 2005 you shield the hot air from the pod, then you create an airflow into the section that houses the pod. a pod filter not only increases air flow, but makes the throttle more responsive as well Link to comment https://www.sau.com.au/forums/topic/76024-pod-or-air-box/page/2/#findComment-1626241 Share on other sites More sharing options...
**JaR** Posted October 6, 2005 Share Posted October 6, 2005 I read in some mags that pod filters are useless....well they are there for the looks and the sound sound like the car is alive, breathing...I like that effect....I replaced my factory filter with HKS green mushroom and ...no difference in perfomance...... <{POST_SNAPBACK}> i do believe your an idiot...... i've got the same pod filter, and like dezz said.... you can feel a sharper throttle response with it there.... Link to comment https://www.sau.com.au/forums/topic/76024-pod-or-air-box/page/2/#findComment-1626417 Share on other sites More sharing options...
elbee111 Posted October 6, 2005 Share Posted October 6, 2005 Hey El BeeAfter being inspired by your photos last night, I hit my stock snorkel with the angle grinder today The results were quite good considering my first real attempt at plastic modification. I haven't had time to do the plastic welding yet, will have to fabricate some pieces, so I just used so heat proof tape for the time being. Looks kinda the same as yours, but ultimately I hope it to look just as "factory" as your creation. Cheers for the idea; tell me what you think!!! Thanks Stan <{POST_SNAPBACK}> Hey Stan, just noticed your post. Yes, I did the same thing (2 stage process). I first ground the section away and as a temporary measure I fashioned some thick cardboard to cover and wrapped it around with duct tape. This was until I could get the car and my mate and the plastic all in the same place. Glad you like it. El Bee Link to comment https://www.sau.com.au/forums/topic/76024-pod-or-air-box/page/2/#findComment-1626438 Share on other sites More sharing options...
performance-wise Posted October 16, 2005 Share Posted October 16, 2005 I like this. A mate of mine did the plastic welding for me.This is on R33 GTSt El Bee <{POST_SNAPBACK}> Thats an excellent idea. I replaced my airbox with a pod a CAI then I got a Hybrid FMIC kit & I couldnt fit the snorkel due to the piping, but this idea should fix that problem. Before FMIC After FMIC Looks like Im getting myself a new grinder Link to comment https://www.sau.com.au/forums/topic/76024-pod-or-air-box/page/2/#findComment-1644301 Share on other sites More sharing options...
Big Rizza Posted October 16, 2005 Share Posted October 16, 2005 I have a pod filter on my R32, but had to remove it to pass the pits. It passed initial inspection because the bracket holding it in place was sufficient to stop it moving around, but apparently there was too much induction noise so it failed first time (the guy was an absolute tosser btw). So I borrowed a factory airbox to get it past the pits. The drive to the pits revealed no big differences between the two as far as performance (my car has a cat-back but is otherwise stock btw). The biggest difference was the change in noise - the factory box is much quieter. I think for unmodified and lightly modified cars, the pod filter has a bit of a placebo effect - you just think you are going faster. I am considering swapping to the factory box on a full time basis to kill some of the induction noise. Link to comment https://www.sau.com.au/forums/topic/76024-pod-or-air-box/page/2/#findComment-1644349 Share on other sites More sharing options...
satanic Posted October 16, 2005 Share Posted October 16, 2005 I've been driving the car for 4 months now; the panel filter was one of the first things I did to the car... as mentioned, the performance to be had from a hi-flow panel filter is very good - i think people would only vouch for them if they worked! During my last dyno tune, we did an experiment with the cover from the air box off (to simulate what a pod would do). The outcome was 5 more rwkw, but think about this... we had a fan aimed straight at the intake, the bonnet was up and it was a "test" environment - there is no way you'll get those conditions on the road. Keep it legal, keep the air box And for those who just want induction noise, install a FMIC and your car will come alive. gR33ddy, where did you get your CAI box from... was it from maxx? He still hasn't replied anyone so I just gave up. The only reason I want one is for RICEY goodness under the bonnet! Link to comment https://www.sau.com.au/forums/topic/76024-pod-or-air-box/page/2/#findComment-1644424 Share on other sites More sharing options...
performance-wise Posted October 16, 2005 Share Posted October 16, 2005 gR33ddy, where did you get your CAI box from... was it from maxx? He still hasn't replied anyone so I just gave up. The only reason I want one is for RICEY goodness under the bonnet! <{POST_SNAPBACK}> Yep, got it from Maxx. Hes on NS.com more than SAU. maybe try him there. Link to comment https://www.sau.com.au/forums/topic/76024-pod-or-air-box/page/2/#findComment-1644449 Share on other sites More sharing options...
Maxx Posted October 18, 2005 Share Posted October 18, 2005 santic: i think i replied u, anyway u have pm p.s. i logon to SAU everyday, skyline man in heart Link to comment https://www.sau.com.au/forums/topic/76024-pod-or-air-box/page/2/#findComment-1649124 Share on other sites More sharing options...
CNR33 Posted October 19, 2005 Share Posted October 19, 2005 so can you have a panel filter and a front mount in vic? <{POST_SNAPBACK}> A hi-flow panel filter in a stock air box with an FMIC is fine, you're only allowed one aftermarket intake mod, so that'd be your best course of action. Link to comment https://www.sau.com.au/forums/topic/76024-pod-or-air-box/page/2/#findComment-1653648 Share on other sites More sharing options...
