  • Replies 162
Yeah guys, i wouldnt worry until we get some definative results. If the Magic cat fails, ill take it back and get a refund! It shouldnt be up to us to test it; but it'll be interesting. Thats IF it fails. im with shif_tea above^^^^.
Should it not be as simple as the company distibuting "Magic Cat" providing documentation to prove that their Cat Converters meet ASE or ADR ( or whatever they are ) requirements / regs ???? It just seems far too simple for the distributors to clear their name and get back on with selling their product........ :confused:
I guess on the other hand.......is there any documentation available for the "Catco" Cats that says "it" is approved for use in Australia under ADR's etc ??
I know the US / California regs are more strict than ours, but that does not mean by default that the parts are accepted for use in AUS.
I guess another question would be: Is ASE Engineering Approval required for the fitment of one of these cats since neither is OEM fitment.
Not trying to stir up any $hit. Just throwing a few more bones out there for all to chew on :(
Quick update;
I have a new Magic cat for the test
Thanks to BATMBL, I now have the measurements of the Catco (flange to flange is 317mm)
So I can now get the Magic cat's flanges welded on to those dimensions
That will make a swap over easy, if it is necessary
Thanks to ABFLUG we have a RAWS standard facility to test the emissions
I will post up more progress as it happens:cheers:
Quick update;
whilst you are at it should you want to compare to a genuine GTR car I have one sitting around. would be a good basline.
1. What diameter are the flanges/exhaust on the test car out of interest?
2. Still planning a dyno test?
3. My plans have been a delayed a little, so if you need another Magic cat for testing I have one sitting on my floor :(
Lucien.
Hi LW
1. 3.25"
2. I know the magic cat doesn't loose any power over a 3" piece of pipe on a car with 300 rwkw, already tested that several months ago. If we have time when tuning the Stagea I might do a back to back comparing the compliance cat with the Magic Cat. But I already know the compliance cat is crap, so it won't tell me much.
3. Might take you up on that, have you had the flanges welded on yet? If so what's the flange to flange measurement? (Hopefully ~317mm).
It has been my experience that genuine GTR cats are very good. What is the flange to flange measurement? (Hopefully ~317mm). If it is, then I might take you up on it as well, that way I can do a 3 way back to back. If BATMBL wants to loan me a Catco, I will make it a 4 way, emissions and dyno test. As long as ABFLUG doesn't mind doing 4 emissions tests.
PS; Julian/Ben/Martin if we do this, and I write an article, will you publish it?
No flanges welded on:  its still in its (dodgey) box and bubble wrap from Magic.  My interest -- hence the question -- in the dyno test is more to see if the Catco also has no negative impacts on performance.
Cheers,
Lucien.
This is growing all the time. If I borrow your Magic Cat, it will come back with stainless steel 3.25" flanges welded on it. Is that OK with you? Let's take this off line via PM if you like.:(
I'm excited!! this is the showdown of the century, beats all that shapelle corby sh1t for intrigue and suspense by far!! they should make a drama miniseries about this i reckon!!
EDIT: SK if those girls in your pics are in your crew, can i be too?? I'll do whatever you want, fetch drinks, clean the floor, polish your engine bay (thats not some sort of sexual metaphor either, it was literal). I'm beginning to think that i'm definitely in the wrong field!!!
I can see it now:
"Its a story, about a man and his Catalytic converter. Stuggling against the odds to clear his name, and finally be re-united with his exhaust"
Rivetting stuff, reckon we could get Russell Crowe to play the lead?? And someone like Al pacino to play BATMBL's part. hahaha
Ready when you are SK just let me know.
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
