  • Replies 43
Check the air reg down where the injectors are.That may be dirty inside aswell.There is 2 10mm bolts holding it down and 2 fat hose's each side.
__________________
is it square shaped type off thing?
can anyone think off a reason why it will idle high when AAC valve conected
but idles normally when its not???
https://www.sau.com.au/forums/topic/76317-aac-valve/page/2/#findComment-1408971
It still idles high even when I disconnect it... I admit it does drop, but not a lot and it still idles way too high and now this hunting thing is driving me mad, I will sit at the lights and it will bounce between 1000 and 2000, bloody irritating!!
https://www.sau.com.au/forums/topic/76317-aac-valve/page/2/#findComment-1409000
Okay, I disassembled and reassembled my AAC valve, didnt do anything, Im in the process of putting the Air regulator back in, just waiting for gasket goop to dry. I think this might do the trick as the spring wasnt under any tension which would suggest that the plate couldnt move due to being in the incorrect position. I will post later to confirm If it worked
https://www.sau.com.au/forums/topic/76317-aac-valve/page/2/#findComment-1409955
Well the Air regulator is back in and the car idles around 1000 and stays there, no more hunting for me!! I gotta say it was pretty easy and you can't really go wrong with the internals of the regulator, they only go in one way.. I'm happy with the result.
eXc your guide was how I started out repairing the valve, great one mate. Cheers
https://www.sau.com.au/forums/topic/76317-aac-valve/page/2/#findComment-1410308
i sorted out most of my prob
found that the turbo smart blow off valve is most likely after i dissconnected it i had allmost no drop in idle at all and never stalled
connected it and again after pulling up at light ect.. it would stall and drop really low idle
i opened the bonnet and reved the car and watched the BOV found that it was sucking in air because the valve would not fully shut
so now its disconnected
maybe the rest of the prob is the fuel pump
as silvia pumps operate with a ground swith that at idle it drops the current to the pump so low that it cant operate properly (i have GTR pump)
so on the weekend ill find the earth wire from the pump and run my own bigger gauge earth to a earth point in the boot
hopefully it fixes the prob or ill have to run a new cable from the switch and new relay also with same gauge wire
hope it works
cheers
matt
https://www.sau.com.au/forums/topic/76317-aac-valve/page/2/#findComment-1412432
timmy c
The air regulator has two bolts holding it to the intake manifiold, get those out and two hoses and connector and your on your way, you can take more hoses off to give yourself more working space as well. eXc's tutorial is good try use that, getting it out was the hardest part. It will require a little patience, but will come out. The screws on the air regulator are tough ones, but I sprayed them with a bit of lubricant and used a quality phillips screwdriver head and just moved it a little at a time, also helps if you push down on the screw to stop it stripping the head, I thought they wouldnt come out, but with a bit of patience(again) they came. If you got anymore questions post away
Good luck mate.
blackrb20silvia let us know how the pump goes
https://www.sau.com.au/forums/topic/76317-aac-valve/page/2/#findComment-1412973
Hey guys,
Took my regulator apart today. Is the spring supposed to hold the rotating thing shut entirely? Mine is half open? It wasn't dirty at all either so maybe its the AAC instead....
I put it all back together and now the idle is high :D its idling at around 1500. Before it was fine, I don't think i've changed anything. Its shit!
Anyone got any ideas?
https://www.sau.com.au/forums/topic/76317-aac-valve/page/2/#findComment-1415867
I played with the water temp correction(wrote down what setting it had first so I could set it back if need be) table and thats why it revs high when cold.I got it idleing at 1000rpm when stone cold but it was rough.
https://www.sau.com.au/forums/topic/76317-aac-valve/page/2/#findComment-1416251
Yeah I fixed the problem, I put in a stronger spring then factory. It idles up fine but now when warm it drops straight down no messing about. :(
It still hasn't fixed my start up issue though. When I start the car in the morning I have to give it some throttle or it sits around 200RPM and coughs and dies.
The guide is good but the pics don't works anymore.!
https://www.sau.com.au/forums/topic/76317-aac-valve/page/2/#findComment-1417068
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
