Hi as the proud new owner of a series 2 R33 I am seeking to buy (not straight away) a Power FC and FMIC can anyone help me in terms of good places to get these from for a not too steep price and where they know what they are doing. How much am I looking at all up? Cheers!
Hey fella, I get my car tuned at Graham West on Marion Rd, They sell PowerFC and have a sht load of data for them, really down to earth guys, not too sure how much but check them out!!
Darren :uh-huh:
I normally use nengun.com & greenline.jp as a good price reference. Also, check out the 'group buys' section they regularly have cheap FMIC & Power FC's.
Not sure where you live, but some reputable workshops/ mechanics which many on here go to are - Tilbrook, Boost Worx & Morpowa (that's where I take my car).
In terms of mechanical services & dyno tune prices your looking at:
5,000kms service $120-$220
General dyno tune $140-$250
Initial Power FC dyno tune $400-$600
Have fun with the line.
like pkblade stated there are many places where you can get pfc and fmic's from. Its best to look around and find out general prices b/c bargains comes up all the time especially in the for sale section and group buys. btw if you want some maintence done to car at a relatively cheap price refer to this thread here. http://www.skylinesaustralia.com/forums/sh...ead.php?t=74556
you'll find PowerFCs with hand controller delivered for around $1,000 through traders on nissansilvia.com, and Ebay is your best bet for a Hybrid FMIC if you want a cheaper option cooler (I have one of these and they are great) - I think kits with piping are going for around the $900 mark atm.
Yeah I got my POWER FC and Hand Controller via BUSKY from the nissan silvia forums..
It was delivered in under 2 weeks.. and passed customs no probs.. coz the guy wrote.. USED.. R34 POWER FC..lol.. so didn't pay any import customs tax.. but yeah .. ppl in adelaide were quoting $1600+ and I was fark..no.. for $1650 I got POWER FC and AVCR. So yeah shop around in forums.. as for FMIC.. I got my blitz coming from nengun.com. Apparently the HKS aluminium was on sale a few weeks ago.. only $1500 or so.. compared to $2000+ others ask for locally.. correct me if I'm wrong on some of these prices but.. yeah.. I reckon they are pretty accurate.
But for instant cheap power do a search on the forums..concerning changing the solenoid in the R33 to make it 10psi.
If only I could do it on the R34... :whatsthat
Have fun boosting mate..
Iceduck out
:Pimp2:
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
    • Sorry, just assumed that talk of coloured pads meant EBC red/green/yellow/shit stuff. I don't know the DBA pads, but it's a reasonable bet that they will be OK. DBA make good stuff generally. Those 4000 series rotors I linked to are very good. I may well replace the RDA rotors I have with those when required.
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
