Is anyone out there using Motul synthetic gearbox and diff oil? What products are you using specifically and what has been your experience. I am looking at (for the gearbox) Gear 300 75W90, or Motylgear 75W90. What grade oil does the diff use? I am assuming 75/90 too.
I am very happy with the 300V for the engine and thought I would give Motul a go at my gearbox and diff. I DO NOT want to hear about Redline.
I have searched and only found vague information re: motul gear oils.
thanks
-rb25
https://www.sau.com.au/forums/topic/76336-motul-gear-oil/
I have Motul gear300 oil in the gearbox. before it i had castrol in there, and i must say the difference was amazing. Alot of the notchiness went, and the gears feel alot smoother. But i'm goin to go for a better gearbox oil on my next change
https://www.sau.com.au/forums/topic/76336-motul-gear-oil/#findComment-1404937
Hey there mate, I have an S15 which is about to go in for a FULL service(diff, gearbox,brakes, plugs, radiator etc). I went for Motul 8100 XS 5w-40 full synthetic for the engine, Motul Gear300 75-90 for the gearbox and Motul GEARBOX 80-90 mineral for the diff. DO NOT use Motul FF-LSD if you have the stock LSD!!!! I know this sounds very strange but the S15 manual says to use NON-LSD oil for the gearbox and diff(which GEAR300 and GEARBOX are NON-LSD). I think FF-LSD is to be used with lockers and mechanical diffs. Bear in mind you could use GEAR300 for the diff also, i opted not to because the manual states the S15 diff needs 80w90, not sure if i could get away with using full synthetic Gear300... would love to try it for the diff sometime.
https://www.sau.com.au/forums/topic/76336-motul-gear-oil/#findComment-1405014
Thanks for the replies guys. I'll reply to this thread after a few hundred kays with the oil change.
Not happy with it.  The cheap s  hit stuff that was in there that was thicker was better.  Or felt better.  Once its warm its ok, but by geebus it takes forever to warm up.
Dave, I had the same problem with the Redline oil, you really had to give the car some stick before the gearbox felt any good or else it was very 'notchy'.
rb25
https://www.sau.com.au/forums/topic/76336-motul-gear-oil/#findComment-1405865
