Anyone have an aftermarket cup holder in their 32, 33 skyline that proven to be reliable? Reliable as don't break after a week or so ( like those TypeS bullshit i bought at Kmark that only last a week )? Anyone use/known any reliable brands?
I heard some ppl do conversion by putting some others car's manufacture stock drink holder in their skylines, is this true? If so can someone post pic up?
Cheers
https://www.sau.com.au/forums/topic/76418-after-market-cupholders-conversion/
try the DIN sized units which have a little compartment for storage as well as for two drinks. never broke on me and held my cups pretty reliably. Only problem is, they don't fit the 600ml pet bottles by a fraction.
Got mine at autobarn for $40 i think.
Good luck with it.
my fones playing up so i cant show pics,but i got these two 'AC HOLDER' with Hot & Cold written on them with an american flag,but i ripped the flag crap off.so yeh two of the best cup holders,sterdy, they stick in the middle air con vents.they adjustable to fit 3 different size cups, cand fit sweet i know that. i guess the idea is you turn your air con ON to keep drinks cold.
Sound good, don't realy care about warm/cold as long as they stay steady, no spilling....and last. Put pic up whenever you can. Thanks.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
